chopderek Posted January 12, 2012 Report Share Posted January 12, 2012 Is this something that will work for my son's car? Quote Link to comment
izzo Posted January 12, 2012 Report Share Posted January 12, 2012 Time, money, some fabrication. It could work. Quote Link to comment
chopderek Posted January 12, 2012 Author Report Share Posted January 12, 2012 So with some engine mount mods and some work it will fit? His 1200 is auto trans so has big hump. Quote Link to comment
izzo Posted January 12, 2012 Report Share Posted January 12, 2012 Possibly, i can't remember what all needs to be done sorry. Use google to search the site, its been on here a time or two. I can't quite recall what all was needed. Quote Link to comment
DRIVEN Posted January 12, 2012 Report Share Posted January 12, 2012 http://datsun1200.com/modules/mediawiki/index.php?title=L-series_Engine_Swap Quote Link to comment
datzenmike Posted January 12, 2012 Report Share Posted January 12, 2012 http://datsun1200.co...ies_Engine_Swap L20B Sources USA L20B engines came in these models: Datsun 620: 1975-1979 Datsun 720: 1980 only Datsun 510: 1978-1979 Datsun 200SX: 1977-1979 (1977 U67 square port ex. head, 1978-1979 W58 round port ex. head) ADD: Datsun 610 '73-'76 Datsun 710 '75-'77 Quote Link to comment
ggzilla Posted January 12, 2012 Report Share Posted January 12, 2012 Lot of guys have done this swap. Doesn't take long if you get the right parts L-series parts. Swapping the rear axle is the hardest part. Engine + transmission from 1977-1979 200SX or 1978-1979 510 will fit right in. Use the 1200 automatic driveshaft. Already has the right rear crossmember, but may need to be reversed. You can use B210 or B310 H150 center pumpkin, but it is marginal strength. A young driver will probably break it. Minor fabrication * Cut engine crossmember towers down, weld flat plates at same angle as L20 crossmember. Or adapter plates for the 1200 engine mounts might work. * Throttle cable adaptor * Wiring length & location changes * Radiator mounting (use flat plates to space out the stock bolt holes) * Radiator hoses * electric fan Major fabrication * Exaust piping. use larger pipe and muffler than 1200 came with * Fit a H165 rear end assembly. 710 or A10 can work, but needs wheels with more positive offset as these are wider. Needs a shorted driveshaft OR, just spend $2500 hopping up the A12. Oops, that still won't make as much power as the stock L20B. Quote Link to comment
