Yellow_Feva Posted January 11, 2012 Report Share Posted January 11, 2012 OK today I was installing my new wheels and tires and go to start my car and notice that there's a huge fuel leak coming from under the car so I immediately turn it off and try to find the spot where it's coming from. Should these lines be attached? Here I find these 2 lines attached by zipties and 1 line is leaking. The other picture indicate were the lines are coming from. Any help would be greatly appreciated. Quote Link to comment
john510 Posted January 11, 2012 Report Share Posted January 11, 2012 Those are the overflows for the float bowls.You might have a stuck float or there not adjusted properly. Quote Link to comment
MikeRL411 Posted January 11, 2012 Report Share Posted January 11, 2012 First gently tighten the bolts on top of the banjo fittings. Next take a small block of wood, place on top of the housing or banjo and give a gentle tap with something less than a 3 pound sledge hammer. This will usually loosen a stuck float. Third, jiggle the "wire" protruding from the bottom of the float bowl. This will usually dislodge small crub blocking the output float needle [you do have a working gasoline line filter don't you?] Quote Link to comment
Yellow_Feva Posted January 11, 2012 Author Report Share Posted January 11, 2012 First gently tighten the bolts on top of the banjo fittings. Next take a small block of wood, place on top of the housing or banjo and give a gentle tap with something less than a 3 pound sledge hammer. This will usually loosen a stuck float. Third, jiggle the "wire" protruding from the bottom of the float bowl. This will usually dislodge small crub blocking the output float needle [you do have a working gasoline line filter don't you?] I am a total noob when it comes to these carbs so bare with me ;) Ok so the problem is with the float closest to the radiator cause that's the one that's leaking. Now the bolt that I have to adjust is the black one on top of the dome? then tap it gently? Or are u talking about the 4 bolts on the plate were the line is coming from? Quote Link to comment
Yellow_Feva Posted January 11, 2012 Author Report Share Posted January 11, 2012 Ok found the problem, the float closest to the radiator is full of gas and at the bottom so now where do I get a rebuild kit or a float? Quote Link to comment
RedBanner Posted January 11, 2012 Report Share Posted January 11, 2012 Ive soldierd and filed I webber one and got it to work, drill out any cracks before hand tho or youll re crack it later, also it helps it not blow up while you soldier it. I just lit mine in fire to ckean the gas off/out, maybe I just got lucky tho. Quote Link to comment
k-autic Posted January 11, 2012 Report Share Posted January 11, 2012 the problem is gas is leaking into your float. You can get them from ztherapy.com the phone number is 503-587-9800 they will take care of you it looks like you have 38mm carbs but i might be wrong. It was 20 dollars a piece plus 5 for shipping. Quote Link to comment
Yellow_Feva Posted January 12, 2012 Author Report Share Posted January 12, 2012 the problem is gas is leaking into your float. You can get them from ztherapy.com the phone number is 503-587-9800 they will take care of you it looks like you have 38mm carbs but i might be wrong. It was 20 dollars a piece plus 5 for shipping. Actually found them at my Nissan dealer for 13 dollars each. Part # 16061-k1407 And yes they are the GX 38MM carbs Quote Link to comment
