spooge93 Posted January 8, 2012 Report Share Posted January 8, 2012 Just like the title says. Need torque specs on all bolts with specific torque requirements. Thanks for all the help Quote Link to comment
Skib Posted January 8, 2012 Report Share Posted January 8, 2012 chilton/hayns/FSM Quote Link to comment
spooge93 Posted January 8, 2012 Author Report Share Posted January 8, 2012 chilton/hayns/FSM none available in my area at the moment. All i need is headbolt, cam and crank bolt specs Quote Link to comment
Pacific coast Datsun Posted January 8, 2012 Report Share Posted January 8, 2012 Try www.olddatsuns.com the info may be there. Quote Link to comment
datzenmike Posted January 9, 2012 Report Share Posted January 9, 2012 none available in my area at the moment. All i need is headbolt, cam and crank bolt specs Headbolts Tighten in this order.. R A D 7 8 3 4 1 2 5 6 9 10... to 20 ft lbs, start over again at 1 and torque to 40, start over again at 1 and torque to 60 ft lbs. Bolts and block threads scrupulously clean and drop of oil on the top of washer. Cam retaining bolt on front sprocket?.................... 87-116 ft lbs. Crank bolts? you mean main bearing caps?........ 33-40 ft lbs Quote Link to comment
Guest 510kamikazifreak Posted January 9, 2012 Report Share Posted January 9, 2012 Headbolts Tighten in this order.. R A D 7 8 3 4 1 2 5 6 9 10... to 20 ft lbs, start over again at 1 and torque to 40, start over again at 1 and torque to 60 ft lbs. Bolts and block threads scrupulously clean and drop of oil on the top of washer. Cam retaining bolt on front sprocket?.................... 87-116 ft lbs. Crank bolts? you mean main bearing caps?........ 33-40 ft lbs Dont forget that the head bolts with the o around the hex head are higher torque than the ones without * Edit to ad the link Pretty informative http://www.davidcmurphy.com/olddat/620tech4.htm Quote Link to comment
