DanielC Posted January 12, 2012 Report Share Posted January 12, 2012 As the spark plugs wear, the gap gradually increases. The voltage required to fire the plugs goes up. If the voltage required to fire the plugs goes up too much, eventually, it is easier for the high voltage to go somewhere else to get to ground, instead of firing the plug. The insulation in the coil pack, or somewhere else breaks down, and once that happens, if becomes even easier for the voltage to not go to the plug. So, not ever changing the plugs can damage coil packs. Quote Link to comment
ggzilla Posted January 12, 2012 Report Share Posted January 12, 2012 That makes sense. I guess I should check the plugs sooner, like I do for my Datsun every year. Quote Link to comment
