Hurley Posted January 6, 2012 Report Share Posted January 6, 2012 I have never delt with struts before.I have a 1970 510. I baught new cartridges because the old ones are shot. I have the struts out of the car and cant figure out how to disassemble them. Someone help me please! Quote Link to comment
RedBanner Posted January 6, 2012 Report Share Posted January 6, 2012 I have never delt with struts before.I have a 1970 510. I baught new cartridges because the old ones are shot. I have the struts out of the car and cant figure out how to disassemble them. Someone help me please! You can realy hurt yourself dissembling a strut, id try and get someone to show you the first time. If you have an air ratchet set the strut on its side, place your strong foot on the 2 or 3rd coil from the top hat, with the strut tube pointed in a safe direction and the top hat pointed in a safe direction, use the air rathet to blast the top hat nut off , and watch your face. Then remove the coil, remove the gland nut and slide it off the strut, then look for the O ring around the top of the insert, pull the seal the inset should pull out with a little force , then reverse it back in. Quote Link to comment
NCLNDYM Posted January 6, 2012 Report Share Posted January 6, 2012 You need to compress the springs so you can remove the top spring so you can remove the strut bolt in the middle of the spring perch. then pull off the spring and unbolt the large hexagon nut to access the strut insert. you can usually rent a spring compressor from the auto store or do it there. unless you know someone who may have one. Quote Link to comment
datzenmike Posted January 6, 2012 Report Share Posted January 6, 2012 I don't know about that. There's a lot of energy stored in that spring plus this won't work for putting back together. Rent a spring compressor. I just replaced the fluid with 20w motorcycle fork oil. Firmed it right up. I made my own compressor... remove nut Release spring and remove top hat Remove gland nut with pipe wrench... Fish out the O ring... Pour out the thin damper oil. . Quote Link to comment
philcas1987 Posted January 6, 2012 Report Share Posted January 6, 2012 now thats ghetto fab!!!hahaha Quote Link to comment
Guest 510kamikazifreak Posted January 6, 2012 Report Share Posted January 6, 2012 Dont need no spring compressor,nor a rather longish plank :lol: to drop struts out Its easy peasy to get a strut out,have pulled and replaced a pair in less than 45 mins :P all thats needed is Jack(floor),Jack handle,Tire iron,14 and 17 MM sockets,Farmer brown fits all(crescent wrench, only to pivot ball joint).. Quote Link to comment
philcas1987 Posted January 6, 2012 Report Share Posted January 6, 2012 Dont need no spring compressor,nor a rather longish plank :lol: to drop struts out Its easy peasy to get a strut out,have pulled and replaced a pair in less than 45 mins :P all thats needed is Jack(floor),Jack handle,Tire iron,14 and 17 MM sockets,Farmer brown fits all(crescent wrench, only to pivot ball joint).. kami calls it a mexican socket set or a polish micrometer Quote Link to comment
Guest 510kamikazifreak Posted January 6, 2012 Report Share Posted January 6, 2012 kami calls it a mexican socket set or a polish micrometer :rofl: one in the same :w00t: Quote Link to comment
Uber Deaf One Posted January 6, 2012 Report Share Posted January 6, 2012 You can realy hurt yourself dissembling a strut, id try and get someone to show you the first time. If you have an air ratchet set the strut on its side, place your strong foot on the 2 or 3rd coil from the top hat, with the strut tube pointed in a safe direction and the top hat pointed in a safe direction, use the air rathet to blast the top hat nut off , and watch your face. Then remove the coil, remove the gland nut and slide it off the strut, then look for the O ring around the top of the insert, pull the seal the inset should pull out with a little force , then reverse it back in. That sounds awfully safe............. although I can't talk........ my dad and I were about to do the same thing yesterday until he remembered he already has a spring compressor Quote Link to comment
