Glass 620 Cowl hood.
I stumbled across this fiberglass 620 cowl hood today while out searching the wrecking yards.
It had been put in the bed of the truck and then the engine was thrown in on top of it.
The alternator bracket poked a hole in the hood and one of the underside braces is cracked.
I figured if it can't be saved,maybe I will cut out the scoop and let someone make a mold of it.
Anyone seen one like this one? Manufacturer? Brad
  • Replies 4
A lot of fiberglass parts were built in low volumes. Could be anything. The scoop doesn't look like the common chevy one that most guys fit.
Showcar doesn't list any 620 fibreglass panels, just 510, B210, 210 and the usual others.
Does it have a frame underneath it? You might be able to take the frame from under a stock hood and bond it to that one just to get it straight/square. As for the cracks and stuff... Fiberglass isnt too hard to patch, just make sure to wear a mask and gloves and long sleeves when youre sanding. I wouldnt cut it up by any means.
