scooter stuff Posted December 26, 2011 Report Share Posted December 26, 2011 I have two NOS discs in the original boxes. They were bought from Nissan in 1987. Part number- 30100-16E03 Quote Link to comment
Boaty Posted December 26, 2011 Report Share Posted December 26, 2011 Hmm.. Stock 510 clutch should be 7 7/8" OD, 1"x24 spline center. Believe that's correct, anyhow. Quote Link to comment
scooter stuff Posted December 27, 2011 Author Report Share Posted December 27, 2011 These are over 9" O.D. totally different splines. Quote Link to comment
datzenmike Posted December 27, 2011 Report Share Posted December 27, 2011 Ha -ha -ha that narrowed it down. It's a 240mm disc from a FWD May '86 to Aug'87 Maxima. It may fit the '85 through '87 too as the last digit is a descriptor which is for minor things like color. But for sure the '87 VG30E Maxima. About $100 at dealer. Quote Link to comment
ggzilla Posted December 27, 2011 Report Share Posted December 27, 2011 Yes, the last digits of trim pieces often are for different color parts (different versions). The last two digits more often indicate revisions. Usually 03 replaces whatever used revision 1 and revision 2. In this case 30100-16E03 is interchangable with 30100-16E04 and 30100-16E08. 30100-16E04 1988 Maxima 30100-16E08 ??? The may have upped the specs on the clutch, probably some minor thing because these parts interchange. Maybe the spec on the little radial springs It's a 240mm, too large for an L-series engine I think * 24T spline x 25mm input * 240mm diameter Quote Link to comment
scooter stuff Posted December 27, 2011 Author Report Share Posted December 27, 2011 Anyone want to buy them cheap? Quote Link to comment
datzenmike Posted December 27, 2011 Report Share Posted December 27, 2011 I did pull and still have a 240mm wheel. It was on an '80 720 4x4 but the L20B was obviously pre '78. This is not normal so someone changed a few parts around on it. The Z24 and the Z20 option looks to have had the 240mm but so too did the 280 and 300zx. Quote Link to comment
Ratty260z Posted December 27, 2011 Report Share Posted December 27, 2011 The 240mm clutch was on the 2+2 version of the z and on the turbo 280zx as well. Quote Link to comment
