banzai510(hainz) Posted December 12, 2011 Report Share Posted December 12, 2011 the alternator should load down abit with heater lights and wipers ON If not then the volt reg is bad. Or you have a 100amp alternator in there. getting over 14.5 volts I would be watching it not to boil out the water in the battery. Get a solid state volt reg if your is a external volt reg.Thats just my opinion. Quote Link to comment
josh817 Posted December 13, 2011 Author Report Share Posted December 13, 2011 I did replace both cables. The load tester loaded down the alternator quite a bit. Alternator is internally regulated. Everything seems to be fine. Haven't had a cold day to really see what happens. In Texas, we drive on our roofs. Not even right hand drive, you mad? Quote Link to comment
