RidgeVistaRider Posted December 7, 2011 Report Share Posted December 7, 2011 Hello all you ratsun fans. I am in need of a L18 flywheel. I have a 1975 620 pickup. I spun a rod bearing on L20b, I found a L18 for cheap so I picked it up not know at the time that the flywheel bolt pattern was different. So now I know I need a 5 bolt flywheel rather than a 6 bolt pattern that the L20B has. I'm located in san jose CA. Just let me know I. Need it ASAP Thanks for checking out my post Link to comment
Laecaon Posted December 7, 2011 Report Share Posted December 7, 2011 They are also L16 flywheels. But more importantly, you probably want a 225mm flywheel. Link to comment
datzenmike Posted December 7, 2011 Report Share Posted December 7, 2011 The 225mm 5 bolt flywheel was only made for one year. Better to try for any L16/18 200mm flywheel from a car or 521/early 620 with an L16. Get the 200mm clutch assy and be sure to get tne matching release collar for it too. The one on the L20B transmission is matched to the 225mm clutch. Link to comment
RidgeVistaRider Posted December 8, 2011 Author Report Share Posted December 8, 2011 Thanks for all the good info guys. I think I found one and it's a 200mm. Link to comment
Chris#51EPGraham Posted December 8, 2011 Report Share Posted December 8, 2011 I've got 200mm L16 flywheels for $36 shipped. Link to comment
crackerjack69 Posted December 14, 2011 Report Share Posted December 14, 2011 How do you get such cheap shipping on those? Link to comment
Jester Posted December 16, 2011 Report Share Posted December 16, 2011 $7 flat rate box. Link to comment
