Front pickup sump/oil pan for an L18?
72dat
Does anyone know which model came with a front sump that will bolt up to my L18. I need to clear the cross-member in my 1200 so the rear mount wont work. I've talked to a few guys on datsun1200.com and they all sourced them from models not in north america.
  • Replies 13
well i called around and didn't have any luck at a new oil pan for the L20b or z20e.
Do you know if the pick up is the same?
i'm thinking that i could take the old oil pan, cut off the bottom then turn it around and weld it back on. I'm wondering though if i still need to find the pick up or if the old one will work and i just turn it around also.
