DISLEXICDIME Posted November 14, 2011 Report Share Posted November 14, 2011 My box flared car has 200sx calipers with z31 rotors in the rear, awesome right? the braking power is sweet! but the way the brake lines are done is scarey. my brake lines are several hoses hooked together some new some original and cracked to hell. so i was wondering if some of you guys that have done the disc swap could show me a pic or 2 of how you did yours. this is my first dime with disc's. Quote Link to comment
510kevin Posted November 14, 2011 Report Share Posted November 14, 2011 the setup i got from phil has the datsun parts llc steel braided lines. the passenger side rep[laces the factory line to the distribution block up under the car. the driver side runs to the end of the factory hardline. awww yeah, plain and simple! Quote Link to comment
rpowell25 Posted November 14, 2011 Report Share Posted November 14, 2011 Custom stainless braided with banjo's to the Maxima calipers. Passenger side goes to the dist block and drivers side to the hard line connection point. I did tie them up as it seemed they could contact the half shafts. Quote Link to comment
DISLEXICDIME Posted November 14, 2011 Author Report Share Posted November 14, 2011 mine bounce off the half shaft . i checked out the ones you have kevin not a bad price . Quote Link to comment
compression Posted November 19, 2011 Report Share Posted November 19, 2011 My rear disc conversion brackets (for Maxima calipers) come with instructions on how to do the rear brake lines including where to purchase the parts with part numbers. Techna-Fit is where to buy from and they are not very expensive. Their part number for the rear brake line kit is DM-RCONV. It includes both hoses (steel braided teflon) and the necessary adapter fittings. email me for more info if needed: engineered.datsun@gmail.com Quote Link to comment
Creepy Cruiser Posted November 20, 2011 Report Share Posted November 20, 2011 Yep, we use the ones Aaron set up from Techna-Fit, and they work killer. It takes all the guess work out of it, and they fit perfect. Thanks again Aaron. Quote Link to comment
DISLEXICDIME Posted November 20, 2011 Author Report Share Posted November 20, 2011 dang i already bought some . Quote Link to comment
