wiring noob question
Eagle_Adam
im not a pro but id like to think i can hold my own when it comes to datsuns, however wiring is the only thing im not good at. I have a 74 620 that i just got a stock tach for. I pulled the gauge cluster surround to install the tach and was expecting to see a loose connector hanging back there to plug the tach into. My first question is do automatic 620 even come with a "plug n play" option so to say for a tach or am I SOL?
  • Replies 10
... I pulled the gauge cluster surround to install the tach and was expecting to see a loose connector hanging back there to plug the tach into. My first question is do automatic 620 even come with a "plug n play" option so to say for a tach or am I SOL?
Sorry, missed this. The clock option was on all 620s but the tach only started in '76. There were also two types of tach I believe.
(far right)
The top one plugs in with separate wires the bottom right has a plug which is definitely how the 620s are wired. The top one may be from the 1200 and are pretty much interchangeable, the difference being the clear plastic bezel on the 620 is cone shaped, while the 1200 is flat. Both appear to be an inductive type, in that the wire marked 4 and 5 simply loops through that tab and are not electrically connected to it. One end goes to the neg side of the coil and the other?? I don't know but not to ground or the coil won't work. Maybe to a resistor to ground?
looks like i have the latter of the 2, here's mine guys:
i was frustrated when i first posted this so i moved onto the POR 15 process on the floorpans. Im still going to take a look when im done but are you saying i wont have the plug in a 74 620 wiring harness mike?
On the right side connector:
(close side)
Blue/white stripe goes to a constant +12 (probably for the clock option and not needed on a tach)
Black to ground
Black/Green* stripe to W terminal on fuse box (15 amp) or any +12 volt switched on by ignition.
(far side)
Blue goes to the negative side of the coil. (points or EI dizzy doesn't matter)
Red/Black stripe and Red/Blue stripe is for the illumination lights. I couldn't figure out how to wire into the dash lights/dimmer so just wired them to come on with the key. Ground one +12 the other from a keyed source... could also use the Black/Green* wire (above)source
I'm gonna wire my tach in someday. I have the newer harness in a box somewhere, the one w/ the tach connector on it. Thought about putting the whole harness on my 72, but I want to keep my blinker switch cuz I don't use a clamshell and the new style blinker switch is ugly. Guess I gotta get the motor running bfore I need a tach :D
