jdmdime Posted November 9, 2011 Report Share Posted November 9, 2011 Ive been messing with a friend's 510 wagon trying to get it road worthy. It starts up fine. After idling for a min or two the idle drops to the point that it stalls. If I feather the throttle to keep it running it spits out the carb and struggles to recover from the idle drop. Once I get it to rev up it idles fine for a few mins then the cycle starts over. Also getting it to start moving is a pain. It spits out the carb unless I rev it up and slip the clutch. I know I should just throw the hitachi out the window and get a 32/36 but its not my car and the owner doesnt have funds to replace the carb right now. To me it sounds like a vacuum leak. What do you think? Quote Link to comment
chebetio510 Posted November 9, 2011 Report Share Posted November 9, 2011 That carb is garbage lol.. Quote Link to comment
jdmdime Posted November 9, 2011 Author Report Share Posted November 9, 2011 Indeed... Quote Link to comment
datzenmike Posted November 9, 2011 Report Share Posted November 9, 2011 That carb is garbage lol.. Indeed... All carbs are garbage when not working. The Hitachi is perfect for what it does and when working is a nice compromise between economy and performance but is now about 40 years old and been through 8 owners and enough air to blow up a balloon the size of the moon. The 32/36 is about 1/3 the complexity and much larger. Seems like a lean backfire which would not be apparent when the choke is on. Probably a blockage in the primary jet, maybe water in the bottom of the bowl. Quote Link to comment
banzai510(hainz) Posted November 9, 2011 Report Share Posted November 9, 2011 when it idles se tthe timming. adjust the mixture. ck the dizzy for looseness correct coil in there not getting HOT? ck valave lash. all this dont cost money to try. ck intake ,carb bolts for looseness simple fix. sell the car to somebody that has money and will treasure a 510 olddatsuns.com Quote Link to comment
racerx Posted November 9, 2011 Report Share Posted November 9, 2011 maybe your needle vavle seat took a crap....maybe carb needs a rebuilt..the reason why I said needle valve seat was that my carb was doing that like 6 mos., checked for vacuum leaks, OK, checked ignition, OK, adjusted carb, OK, called Pierce Manifold in Gilroy, CA and they said check the needle valve seat..when this goes South, you'll flood the secondary..then have a hard time starting, adjusting because it's letting in gas when it's not supposed to. Good luck and let us know what happened. Quote Link to comment
