dscottdatsun Posted October 23, 2011 Report Share Posted October 23, 2011 The steering wheel squeaks when making little turns and its starting to get a little annoying. :angry: What would be the best way to lubricate the bearings in the column? Scott Quote Link to comment
datzenmike Posted October 23, 2011 Report Share Posted October 23, 2011 The wheel is likely rubbing the two piece plastic 'clam shell' that wraps around the column just below it. My 620 did it too. Quote Link to comment
Laecaon Posted October 23, 2011 Report Share Posted October 23, 2011 On mine, the contacts for the horn button started squeaking. There is a prong I can see that rubs against a metal strip, seeable right behind the steering wheel. Quote Link to comment
metalmonkey47 Posted October 23, 2011 Report Share Posted October 23, 2011 Did you check your lugnuts? Quote Link to comment
Guest kamakazi620 Posted October 24, 2011 Report Share Posted October 24, 2011 The steering wheel squeaks when making little turns and its starting to get a little annoying. :angry: What would be the best way to lubricate the bearings in the column? Scott First make sure it ain't rubbing the clamshell/steering collum like Mike said,If that ain't rubbing use a steering wheel puller and remove the wheel lube the bearings with wheel bearing gease and put some dielectric grease where the horn circuit connects and you should be good..................................YO!!! Quote Link to comment
Digi7al Trauma Posted October 24, 2011 Report Share Posted October 24, 2011 and dont forget "the squeeky wheel gets the grease" ...sry no other input... mike, laecaon, and Metalmonkey have allready nailed this one it seems Quote Link to comment
