opalbeetle Posted March 27, 2008 Report Share Posted March 27, 2008 Hello all, I am wondering if anyone knows the iside measurement of the strut inserts for a 76 wagon. Or, if anyone knows what alternate inserts may work. Thanks for the info. Todd Quote Link to comment
69FJWagon Posted March 27, 2008 Report Share Posted March 27, 2008 I believe its the same as a 510... just the spindle and brake caliper mount is different... I think, The strut tube should be the same I would have to look at the 710 race car at Troys to be sure Quote Link to comment
bonvo Posted March 27, 2008 Report Share Posted March 27, 2008 the 510,610,and 710 use the same fron suspention if it works on a 510 it will work on a 710 Quote Link to comment
opalbeetle Posted April 3, 2008 Author Report Share Posted April 3, 2008 Thanks for the info. I just did a bunch of 510 suspension stuff so this helps a lot. Quote Link to comment
Mark_Z28 Posted April 10, 2008 Report Share Posted April 10, 2008 the 510,610,and 710 use the same fron suspention if it works on a 510 it will work on a 710 Arent the sway bars different on the 710 than on the 510? If not, I will be looking for stuff for my 74 710 wagon. Quote Link to comment
Guest jaimesix Posted April 28, 2008 Report Share Posted April 28, 2008 I believe the 510,610 and 710 use the same front sway bar . The 710 and 610 use different center brackets/mounting. The side links are the same, but the center brackets in the 510 are independent from the tension rob brackets ( as in a B210.) The 610 and 710 ( I own both cars , no 510 though ) have center brackets that bolt under the tension rob bracket ( one of said bracket side does.) Aside from that issue, all three cars have identical front sway bars ( and FRONT suspension alltogether.) The 610 and 510 share IRS rear suspension as well. The 710 ( in the US ) has rear leaf sprung suspension. I will double check. But I am 95% sure of this. ADDCO has sway bars for all three cars. Jaime.__________________________________________________________ Quote Link to comment
Burabuda Posted April 28, 2008 Report Share Posted April 28, 2008 i'd be careful when using the word "identical" oem part #'s are different aftermarket part #'s are different there are some instances where they will fit both cars, but that comes from test fitting and/or trial and error same thing applies to the front suspension Quote Link to comment
Mark_Z28 Posted May 3, 2008 Report Share Posted May 3, 2008 I have a 280 ZX front sway bar of off a 79, would that bolt up to the 710? Is it much stiffer than the stock 710? If it is that will save me some money on the front end. Quote Link to comment
zerow Posted May 3, 2008 Report Share Posted May 3, 2008 I have a 280 ZX front sway bar of off a 79, would that bolt up to the 710? Is it much stiffer than the stock 710? If it is that will save me some money on the front end. The front track is different between a '10' series car (i.e. 510, 610, 710) and a Z car, something like 3/4 of an inch on each side. That is why the front track changes when we add 280ZX struts for the vented discs. Now, with that in mind, I would *think* that the 280ZX front sway bar dimensions would be different from a 710. If there are any Z people out there that could shed some light, please do so. Quote Link to comment
