Stoffregen Motorsports Posted August 14 Report Share Posted August 14 1 hour ago, iceman510 said: I think that version may no longer be made. Powerbuilt Tools - https://www.powerbuilt.com/ Nope, they don't make it anymore. But they have some other cool gadgets. Quote Link to comment
datzenmike Posted August 14 Report Share Posted August 14 2 hours ago, Stoffregen Motorsports said: I like your advice from yesterday. Swap out the cylinder head and build an LZ instead. From now on, every time I see a thread about improving the Z motor, I'm going to quote you on that. I had a very good running Z24 from an '89 D21 converted to carburetor for use in a '84 720. Very quiet ran awesome. When I sold my 620 that it was in, I kept it and for something to do, and as I had a spare U67 I put it on. What I found was the Z24 timing cover will actually seal against the L head but no bolts fit it. As it only seals in oil spray and fumes a but of RTV on the gasket will do. This avoids having to make a 3/4" filler between an L20B timing cover and the now higher placed L head. The timing chain needs 4 extra links 3/4" plus 3/4" added. If you can find an L series 89mm gasket fine if not a Z24 with a few extra holes and the timing chain area from an L gasket grafted onto the front. The head I scribed the larger cylinder outline on and unshrouded around the valves where they were closest. I rounded the corner like the trumpet end of a velocity stack. There's tons of added compression, so a small loss for greater flow is a fine trade off. 1 Quote Link to comment
Spiff Posted August 16 Report Share Posted August 16 On 8/14/2024 at 7:38 PM, datzenmike said: What I found was the Z24 timing cover will actually seal against the L head but no bolts fit it. As it only seals in oil spray and fumes a but of RTV on the gasket will do. I ran a cometic mls KA24DE head gasket for my Z24 turbo build, of course the timing portion of it didn't fit so I cut that off and just ran the timing section with rtv instead. Never had a problem with it or any leaks. Quote Link to comment
datzenmike Posted August 16 Report Share Posted August 16 This lower left corner near the fuel pump was the thinnest so I added JB weld and filed it down. This hole just behind the pump doesn't exist on the Z24 block so I added JB because the outer edge was so close to it and drilled out the block below... L gasket on Z24 block. One last thing was joining these two holes on the head rather than drilling a hole in the Z24 block. The Z24 head is cross flow so water flow up from the block is fairly even but the L series has more on the manifold side to draw exhaust heat away from the intakes in between. It's just a matter of comparing the two gaskets and punching hols to match. Quote Link to comment
Stoffregen Motorsports Posted August 16 Report Share Posted August 16 7 hours ago, Spiff said: I ran a cometic mls KA24DE head gasket for my Z24 turbo build, of course the timing portion of it didn't fit so I cut that off and just ran the timing section with rtv instead. Never had a problem with it or any leaks. For a more permanent fix, it's real easy to TIG weld those sections and mill them flat. Quote Link to comment
