sdsurf Posted March 26, 2008 Report Share Posted March 26, 2008 Is this possible? What needs to be done? Quote Link to comment
Pacific coast Datsun Posted March 26, 2008 Report Share Posted March 26, 2008 All L trans. will bolt to all L motors. Mike..save up & get a 5 speed, IMO you wont be dissapointed. Quote Link to comment
sjeff64 Posted March 26, 2008 Report Share Posted March 26, 2008 save the engine mounts from your l16. First l20 I got was out a 78 510 used the mounts that were on the motor and couldn't close the hood(looked cool without the hood thou)any way the clutch and pressure plate line up just fine and being you are not changing the length of the tranny no drive line work is needed. But it will still rev to about 4200 on the freeway at 65 mph:mad: Quote Link to comment
sdsurf Posted March 26, 2008 Author Report Share Posted March 26, 2008 All L trans. will bolt to all L motors. Mike..save up & get a 5 speed, IMO you wont be dissapointed. truck is cherry... I don't want to cut the floor yet... Mark, what is your sat schedule? Quote Link to comment
Pacific coast Datsun Posted March 26, 2008 Report Share Posted March 26, 2008 Mike i work 3pm to 11 pm on sat. so ill be free in the AM. BTW the hole doesnt need to be made that big & if you reinstall the shift boot youll never know. i LOVE the 5 speed in my 521,total night & day difference!! Quote Link to comment
dat521gatherer Posted March 27, 2008 Report Share Posted March 27, 2008 use a l16 oil pan on the l20b. your steering will rub on the l20b pan if you dont. Quote Link to comment
sdsurf Posted April 15, 2008 Author Report Share Posted April 15, 2008 The L20b has a 6 bolt flywheel and the 1600 has a five bolt. To put a 5spd to a L16 what needs to be done? Quote Link to comment
datsunfish Posted April 15, 2008 Report Share Posted April 15, 2008 You need the correct clutch and throw out bearing collar for a l20b or l16.In a 521 you have to have the 521 specific oil pan.Have to pound it out a bit for the front crank journal on a l20b.Try to find a dogleg for easy 5 speed install.I have never had an issue with the one in my 620 and that is my worker. Quote Link to comment
sdsurf Posted April 15, 2008 Author Report Share Posted April 15, 2008 What models did the dogleg come in? Quote Link to comment
datzenmike Posted April 15, 2008 Report Share Posted April 15, 2008 The presssure plate and throw out bearing collar are a matched set so keep together when you put the 5 spd in. Quote Link to comment
zerow Posted April 15, 2008 Report Share Posted April 15, 2008 What models did the dogleg come in? '77 -'79 200SX, if memory serves me correctly. Just not the '80 and later. Quote Link to comment
