datasour14 Posted October 4, 2011 Report Share Posted October 4, 2011 anyone know how to separate the fan clutch from the water pump. im thinking sawzall but idk if the shaft would slide.gear puller? is there a water pump for it that isnt intergrated with the fan/clutch? my truck had a punch to the nose when i got it, the radiator was smashed into the fan and broke it it was wobbly and noisy. got one out of a 620 and it locked up right after i got it. Quote Link to comment
ninjabortion Posted October 4, 2011 Report Share Posted October 4, 2011 the shaft is hardened so you shouldnt have much trouble cutting the clutch off without hurting the shaft too bad as long as you take your time. Quote Link to comment
Logical1 Posted October 4, 2011 Report Share Posted October 4, 2011 l-motor-electric-fan-water-pump-mod Quote Link to comment
datasour14 Posted October 4, 2011 Author Report Share Posted October 4, 2011 soo carbon arc gouger? :lol: not really. thanks though gonna get some cookie cuters then and see where this goes. Quote Link to comment
datasour14 Posted October 4, 2011 Author Report Share Posted October 4, 2011 l-motor-electric-fan-water-pump-mod aha nvr mind cutting it when you can just break it, the right way? thanks!!! Quote Link to comment
HRH Posted October 6, 2011 Report Share Posted October 6, 2011 Use a '69 510 water pump. Exactly the same pump, just no clutch. Still available from NPW through our Altrom line at NAPA. Quote Link to comment
