Farmer Posted September 27, 2011 Report Share Posted September 27, 2011 Wasnt there a kit out there where we can use 14" wheels for 620 Kingpin? I thought i read it somewhere. Tried a search but no luck Larry Quote Link to comment
Radiant-Designer Posted September 27, 2011 Report Share Posted September 27, 2011 I have only seen the 15" I thin I heard of one for the rear that keeps the 14" but not sure if that was for the 620. I am not sure if using the parts from a later truck that had discs would be 14" but from what i heard those disc brakes were not all that great. Quote Link to comment
flatcat19 Posted September 27, 2011 Report Share Posted September 27, 2011 Does Klotz's kit not fit the 620's? Quote Link to comment
mklotz70 Posted September 27, 2011 Report Share Posted September 27, 2011 Yes it does, once I machine the inner bearing spacers for it. Stock 14's will fit with a 1/4" wheel spacer www.bluehandsinc.com Quote Link to comment
flatcat19 Posted September 27, 2011 Report Share Posted September 27, 2011 Does Klotz's kit not fit the 620's? Yes it does, once I machine the inner bearing spacers for it. Stock 14's will fit with a 1/4" wheel spacer www.bluehandsinc.com Commission? :D Quote Link to comment
mklotz70 Posted September 27, 2011 Report Share Posted September 27, 2011 sure....I'll send you the same commission I get every time I send someone to beebani. :) Quote Link to comment
flatcat19 Posted September 27, 2011 Report Share Posted September 27, 2011 sure....I'll send you the same commission I get every time I send someone to beebani. :) SWEET!!!...Wait... <_< Quote Link to comment
