mosilva2782 Posted August 30, 2011 Report Share Posted August 30, 2011 does the weatherstripping for the driver and passenger side of a 4dr work on a 2dr? Thanks for the help if u can answer this Quote Link to comment
Laecaon Posted August 30, 2011 Report Share Posted August 30, 2011 I would say it might depend on the brand, but probably not. 2dr doors are longer than 4dr front doors. Quote Link to comment
bananahamuck Posted August 30, 2011 Report Share Posted August 30, 2011 Do you mean the stuff in the channel that actually touches window? If yes we have used some out of a 620 ( which is easier to find in junkyards ) once. Quote Link to comment
Jester Posted August 31, 2011 Report Share Posted August 31, 2011 Do you mean the stuff in the channel that actually touches window? If yes we have used some out of a 620 ( which is easier to find in junkyards ) once. That's what I'm using in my wagon doors. Perfect fit. Quote Link to comment
qwik510 Posted August 31, 2011 Report Share Posted August 31, 2011 does the weatherstripping for the driver and passenger side of a 4dr work on a 2dr? Thanks for the help if u can answer this If you are talking about the seal that goes on the door to seal the door to the body, you can use the 4 door seal but you will come up short. You will need one extra 4 door seal to cut out a patch piece from. If you line it up right, the patch will be along the bottom of the door where it will not be noticed. Just make sure to use some good weatherstrip adhesive to join the pieces together. Quote Link to comment
