yello620 Posted August 25, 2011 Report Share Posted August 25, 2011 I am in need of a couple of parts for a 510(68-73). Trying to help my brother put together a car that came without a motor. He needs: 1. Front crossmember with stock engine mounts on it. 2. 510 oil pan, oil pickup tube. 3. Trans crossmember for longtail 5spd. Probably buy the crossmember from Experimental Engineering. 4. Will probably need a clutch slave to a 510 too. Link to comment
Jester Posted August 25, 2011 Report Share Posted August 25, 2011 I've got the cross member that I picked up at Canby. Trade ya for the one you picked up?????? Link to comment
yello620 Posted August 25, 2011 Author Report Share Posted August 25, 2011 Did not know you got a crossmember at Canby. Still has the stock motor mount stands on it? Link to comment
Chris#51EPGraham Posted August 25, 2011 Report Share Posted August 25, 2011 Got an otherwise stock oil pan with an oil temp fitting brazed into it, with pickup. $48 shipped. Also have a clutch slave core (needs rebuilt) if rebuild kits are available. Link to comment
510kevin Posted August 25, 2011 Report Share Posted August 25, 2011 i have a good clutch slave and hose i just pulled out of my car for the ka swap i have 510 motor mounts(the rubber isolator part) and i have factory 510 tranny mount. let me know, ill do $50 for all 3 shipped to ya. Link to comment
Laecaon Posted August 25, 2011 Report Share Posted August 25, 2011 I have the pan and pickup on my L16. I could let them go. I could drive them over and make a day of it. See the progress of your truck. Link to comment
yello620 Posted August 26, 2011 Author Report Share Posted August 26, 2011 I have the pan and pickup on my L16. I could let them go. I could drive them over and make a day of it. See the progress of your truck. Deal, let me know what you want for them. Link to comment
yello620 Posted August 26, 2011 Author Report Share Posted August 26, 2011 i have a good clutch slave and hose i just pulled out of my car for the ka swap i have 510 motor mounts(the rubber isolator part) and i have factory 510 tranny mount. let me know, ill do $50 for all 3 shipped to ya. I have the rubber isolators coming already, and i need a tranny mount for a long tail trans. I would take you up on the slave and hose though. Link to comment
izzo Posted August 26, 2011 Report Share Posted August 26, 2011 Strange. I put an L20 in my wagon, out of a 620. The pickup tube was the exact same. I heard you have to swap them, but mine were the same so i left it alone. Oil light turns off a second after i fire it up, and its not hitting inside. Link to comment
Jester Posted August 26, 2011 Report Share Posted August 26, 2011 yep. Factory condition with a few years of road grime. Link to comment
yello620 Posted August 26, 2011 Author Report Share Posted August 26, 2011 yep. Factory condition with a few years of road grime. Sounds like a fair trade to me. And you know what i paid for the VG crossmember. :D Link to comment
yello620 Posted September 1, 2011 Author Report Share Posted September 1, 2011 I am in need of a couple of parts for a 510(68-73). Trying to help my brother put together a car that came without a motor. He needs: 1. Front crossmember with stock engine mounts on it. 2. 510 oil pan, oil pickup tube. 3. Trans crossmember for longtail 5spd. Probably buy the crossmember from Experimental Engineering. 4. Will probably need a clutch slave to a 510 too. Parts have all been located now. 1. front crossmember from Jester. 2. oil pan/pickup tube from Laecaon. 3. he will order the EE crossmember, seems the best route. 4. he found a clutch slave somewhere on his own. So, thanks Jester and Laecaon. Link to comment
Jester Posted September 2, 2011 Report Share Posted September 2, 2011 Just glad to be able to help. Link to comment
Laecaon Posted September 2, 2011 Report Share Posted September 2, 2011 YAY Im helpful! Link to comment
