Monkey got a brand new ride!
  • Replies 30
OOps, phone auto correct .
So you know a great deal about these motors eh? It uses a wet clutch correct? So I need a 10W-40 or 20W-50 that's not energy conserving (I think they all aren't). Do you know the oil capacity by chance?
Yeppers, wet clutch. My guess on oil cap would probably be about 3/4 to 1 quart, might be stamped near the filler in cc or ml. You will also most likely need to pull that carb and inspect the jets, the slow jet on a 100 is TINY and will likely be clogged after sitting so long. Highly recommend fogging that cylinder and letting the rings soak for a bit before you try to fire it, Marvel would be best. You might even add a couple ounces of Marvel to the crankcase as well for the initial oil change.
Thanks for the info! I'll pick some up at work tomorrow and fill 'er up.
I might have to forward you a few more questions soon if you don't mind. This little bike is different to say the least.
You came up Monkey. Awesome.
So I was down at some point? blink.gif Dayum, the truth will set you free!
