ggzilla Posted July 27, 2011 Report Share Posted July 27, 2011 I'm getting my spare engine ready to install and discovered the block deck was milled, so the pistons stick up 0.025" (0.635 mm). Can I fit a closed chamber head to this? The stock gasket is supposed to be 1.0 mm installed. So generally how much piston-to-head clearance is required? Say for an L16 or other engine. My engine is Datsun A14 with cast pistons 76mm bore and 77mm stroke. I'm guessing the previous owner used an open chamber head and milled the block to increase compression. I got the engine used without the head. 1 Quote Link to comment
ggzilla Posted July 27, 2011 Author Report Share Posted July 27, 2011 I found this on Wiseco pistons FAQ page: Steel rods in a big block usually require .045. Steel rods in small blocks require at least .036. Most imports can get by with as little as .030. Aluminum Rods generally require .010 more clearance than steel rods. Now to calculate what the clearance might be with a 1.0 mm gasket and 0.025 inch pop-up... Quote Link to comment
wayno Posted July 27, 2011 Report Share Posted July 27, 2011 You have a photo of the face of the head? Quote Link to comment
ggzilla Posted July 27, 2011 Author Report Share Posted July 27, 2011 It has closed chambers (heart-shaped combustion chambers) I'm thinking there is not enough clearance. The head gasket is 1.2mm uncompressed. I might have to obtain an open chamber head like this. Quote Link to comment
zed Posted July 27, 2011 Report Share Posted July 27, 2011 I'm no expert, but I enjoyed setting up the quench / clearance when I built my L18. My clearance is .035" / 0,89mm. Legendary engine builder Smokey Yunick's famous clearance figure was .040". A tight piston to head clearance has long been recognized as one of the keys to getting best performance from a motor. I make your clearance to be 0,365mm? Which may be a bit tight. It would be a pity to put an open chamber head on your block - you will lose the benefits of squish / quench. Maybe look for a gasket with 1,2 or 1,5mm compressed clearance? Another thought - what about knocking? Have you worked out what your compression ratio will be with this head? Have you "cc"d the head? Quote Link to comment
ggzilla Posted July 27, 2011 Author Report Share Posted July 27, 2011 Thanks. I think a 1.6mm gasket would do it, but don't know where to get one except for those $100 copper gaskets. I'm trying to keep the costs down if possible. Quote Link to comment
king bee66 Posted July 27, 2011 Report Share Posted July 27, 2011 i have a "728 402" head thats surface looks identical to the 1st one you posted. the motor it came off of had dished pistons; for extra clearance i always assumed Quote Link to comment
ggzilla Posted July 27, 2011 Author Report Share Posted July 27, 2011 Dished pistons is how they adjusted compression ratio in the A-series. Most of the heads have the same CCs, but different engines have different piston dish. Nearly all A-series pistons are dished except for non-USA 1000 Coupe and A12 GX hi-octane option and their Cherry counterparts. The most telling example is 1981-1982 all used the same head A12, A14 or A15, same head but different piston dishes. But I see ther are no valve reliefs cut in the pistons. That might be a problem too. Quote Link to comment
zed Posted July 27, 2011 Report Share Posted July 27, 2011 I would check valve to piston clearance with the soft solder wire method, just to get an idea. Datzenmike probably has all the answers here Quote Link to comment
king bee66 Posted July 30, 2011 Report Share Posted July 30, 2011 please keep this updated Quote Link to comment
Master-O-Turbonics Posted July 30, 2011 Report Share Posted July 30, 2011 This is who you should use for a copper gasket. They have thicknesses from .020"(~.5mm) to .100"(2.54mm) for any gasket and they have an L series gasket. Hussey Copper gaskets Quote Link to comment
ggzilla Posted July 31, 2011 Author Report Share Posted July 31, 2011 Thanks! I was wondering about that. Quote Link to comment
