Rotary510 Posted July 18, 2011 Report Share Posted July 18, 2011 ANYONE has a picture of the way the electronic ignition coil and resistor rectangle should look on an L18?speficically, i want to make sure i connected the correct wires. there is a wire that has a "Y" to it and I am not sure where this one goes? Also, my wiper motor is getting HOT with keey in the ignition ON, any ideas? Also, my SU's are getting gas, now they have gas all the way to the bottom of each of the SU's but they won;t shoot gas up into the engine gas chambers. ideas? I need this car running ASAP! It has been sitting for at least 6 months. Willing to pay someone to adress these issues! Eddie :) Quote Link to comment
Rotary510 Posted July 18, 2011 Author Report Share Posted July 18, 2011 i forgot to mention that my L18 has a white rectangle with two connectors on it, basically what color of wire goes where dammit?! Thanks! Quote Link to comment
RedBanner Posted July 18, 2011 Report Share Posted July 18, 2011 like this? if,thats what you need ill get better pics Quote Link to comment
RedBanner Posted July 18, 2011 Report Share Posted July 18, 2011 On my sunny by the way Quote Link to comment
Rotary510 Posted July 18, 2011 Author Report Share Posted July 18, 2011 mine is a 72 510 with an L18, is it the same? Quote Link to comment
RedBanner Posted July 18, 2011 Report Share Posted July 18, 2011 (edited) Idk if the wire colors are the same, but I got that resistor off a 75 dime, so..... Yes? A guess but an educated one. Id check wipers for ground, maybe ad one. Edited July 18, 2011 by Noflagredbanner Quote Link to comment
banzai510(hainz) Posted July 18, 2011 Report Share Posted July 18, 2011 go by my wires color I sent to you.the "dimequarterly" has the wirecolors in the electrical section!!!! 1 Quote Link to comment
RedBanner Posted July 18, 2011 Report Share Posted July 18, 2011 go by my wires color I sent to you.the "dimequarterly" has the wirecolors in the electrical section!!!! Good save, +1 Quote Link to comment
datzenmike Posted July 18, 2011 Report Share Posted July 18, 2011 Also, my wiper motor is getting HOT with keey in the ignition ON, any ideas? Wiper motor is trying to complete its wiper motion and park at the bottom of the windshield. Once parked it should shut off. Seems like it's jammed. Lift both wiper arms off the windshield and see if they will move. Also, my SU's are getting gas, now they have gas all the way to the bottom of each of the SU's but they won;t shoot gas up into the engine gas chambers. ideas? I need this car running ASAP! It has been sitting for at least 6 months. You're saying that there is gas in the float chambers? SU's are unique in that they do not shoot gas. Other carbs have an accelerator pump to squirt gas into the manifold to richen the mixture when the throttle is depressed. Quote Link to comment
