Siqx20 Posted July 17, 2011 Report Share Posted July 17, 2011 Is there anyone in southern oregon that has done it and would like to do mine? lol They are completly shot. Or maybe a write up somewhere so i can try my hand at it myself?? I kno it is pretty bad and most of the floor pan is gone. only thing keeping my feet off the asphalt is carpet lol Quote Link to comment
Farmer Posted July 17, 2011 Report Share Posted July 17, 2011 Might be better to find another cab. Larry Quote Link to comment
Siqx20 Posted July 17, 2011 Author Report Share Posted July 17, 2011 For real?? Its mostly only right where ur heel sits. it hasn't gotten up to the seat mounts or anywhere close for that matter. Quote Link to comment
Farmer Posted July 17, 2011 Report Share Posted July 17, 2011 Oh. Its only rusted at the feet area then shouldn't be a problem welding in a patch. I though you were talking about all over. It hards to replace the area around the cab mounts. Larry Quote Link to comment
Siqx20 Posted July 17, 2011 Author Report Share Posted July 17, 2011 yeah around the cab mounts arent too bad. they are starting to get there but thats why im wanting to get on it soon so it doesnt get any worse. You scared me there for a second larry.... not cool. Quote Link to comment
Wide14u Posted July 17, 2011 Report Share Posted July 17, 2011 if it was worse you could do a body drop on it but if that small just screw in a plate tell you get to a buddy house that can weld it in for you Quote Link to comment
Siqx20 Posted July 17, 2011 Author Report Share Posted July 17, 2011 well its not a big deal at the moment. like i said my carpet keeps my feet up at the moment. im just creating a plan of attack. I wanna redo all the interior when im in there so it will all be happening in the fall probably. Quote Link to comment
wildmaninid Posted July 17, 2011 Report Share Posted July 17, 2011 Putting up a few oics of the affected area would be nice. Ill tell you that 19 years ago, my dads 79 pickup had some bad rot on the heel area, we used the "extend" rust converter product that turned all the cancer rust black, cleaned it all up good top and bottom, and used some industrial kitty hair.....its like fiberglass boat repair compound, has many strands of cut up fiberglass and resin all in a can.....use hardener to activate it. Anyhow we put a piece of thick abs plastic sheet ;hell cardboard would work too, and we smeared it all over the rust and this stuff is strong as hell. Had a nice new area in the truck. Then we used a spray undercoat top and bottom to seal it out. Still holding up just fine, and the truck has been sitting out under a tree with no glass in it for several years as parts and its still ok. But I bet if you did this, and used the bedliner on your floor like I did in my build thread, you could fix it up nice with no welding involved.....but depends on the sizes of your holes. Quote Link to comment
bustedknuckles Posted July 17, 2011 Report Share Posted July 17, 2011 if u were in the medford ashland area and had the sheet metal to patch in i would be happy to weld it in there for you Quote Link to comment
Siqx20 Posted July 17, 2011 Author Report Share Posted July 17, 2011 Dude im in grants pass im jst down the road. Guess I should update my location since I moved ;) Quote Link to comment
bbqbill Posted July 18, 2011 Report Share Posted July 18, 2011 this is what i startea with Quote Link to comment
Siqx20 Posted July 18, 2011 Author Report Share Posted July 18, 2011 After pic? Quote Link to comment
bustedknuckles Posted July 18, 2011 Report Share Posted July 18, 2011 well if u are in gp then when u are ready and have the supplies for it id be happy to help weld it in there for you just let me know Quote Link to comment
bbqbill Posted July 19, 2011 Report Share Posted July 19, 2011 it now has no floor. made one out sheet metal ,but had to put on hold for a bit.i will post when its in. Quote Link to comment
