primo74620 Posted July 15, 2011 Report Share Posted July 15, 2011 I want to know if a Weber 32/34 will fit on my 74' 620? Quote Link to comment
Wide14u Posted July 15, 2011 Report Share Posted July 15, 2011 yes with the adapter Quote Link to comment
primo74620 Posted July 15, 2011 Author Report Share Posted July 15, 2011 yes with the adapter Thanks!!!!!!! Now where can I find installation instructions? Quote Link to comment
primo74620 Posted July 15, 2011 Author Report Share Posted July 15, 2011 I found it at the jy on a 720. Will I need a different adaptor????? Quote Link to comment
Wide14u Posted July 15, 2011 Report Share Posted July 15, 2011 what year 720 if its a early 720 it should go right on on the later it might be a little wider but should still work Quote Link to comment
ggzilla Posted July 15, 2011 Report Share Posted July 15, 2011 You can buy parts, adapters and throttle linkage kits at RedlineWeber.com They have adapters for Datsun engines. Quote Link to comment
primo74620 Posted July 15, 2011 Author Report Share Posted July 15, 2011 You can buy parts, adapters and throttle linkage kits at RedlineWeber.com They have adapters for Datsun engines. Thanks ggzilla!!!! Quote Link to comment
LenRobertson Posted July 15, 2011 Report Share Posted July 15, 2011 I've heard many scare stories of cracked adapters due to over tightening. Is is a good idea or bad one to use Loctite on the screws that hold the adapter to the manifold, rather than over tightening? What color Loctite? If Loctite is not recommended, how about a torque value for the adapter screws? Oil the threads or install dry? Len Quote Link to comment
ggzilla Posted July 15, 2011 Report Share Posted July 15, 2011 Use loctite regular (not permanent). Or use lock washers, and torque appropriately to size, e.g. M8 bolts only need 10 ft.lbs or so to be fully tight. Quote Link to comment
