200sx 5speed dogleg leg shifter
  • Replies 5
the z shifter put a to far back in standard cab truck for me i got one from a 720 4x4 is shorter than 620 shifter
Actually....there are about 4 different shifters from the 720.
Short tail.... long tail trannie....reg cab...king cab...4x4......etc
Did you try putting it in backwards? To move the shifter forwards?
620 and two 720 type below it. I tried the bottom one in my 710 in both forward and backwards to see which was best. The later car shifters (after 80) look like the bottom two and may or may not fit the earlier dogleg because of the differences in the cross pin height.
