pharouh Posted July 9, 2011 Report Share Posted July 9, 2011 This is my 73 620 with an engine out of an early 70's 510. I've had to redo the harness,and don't have a lot to go by. I used the FSM,and I know how to read a schematic.I hooked up the battery for the first time today,and when I touched the cable to the ground side,it sparked and I could hear the starter motor. I did NOT leave it on very long. Is this backwards,or am I missing something? Quote Link to comment
Wide14u Posted July 9, 2011 Report Share Posted July 9, 2011 thats not the ground wire is it Quote Link to comment
datzenmike Posted July 9, 2011 Report Share Posted July 9, 2011 Black wire goes where the red wire is now. The red wire looks like the start signal from the key and (should be black/yellow stripe) goes to the small terminal in between. Quote Link to comment
pharouh Posted July 9, 2011 Author Report Share Posted July 9, 2011 Thanks,Mike I hoped you would see this. The black wire is the positive. Both cables are black. The red wire was already on the starter when I got it. How do I fasten it to the middle? Thanks! Quote Link to comment
datsunaholic Posted July 9, 2011 Report Share Posted July 9, 2011 Take the red wire off. It doesn't belong. The black goes where the red is. The wire plugged into the red goes to the spade terminal on top. Quote Link to comment
pharouh Posted July 9, 2011 Author Report Share Posted July 9, 2011 I took it out to get a better look. Looks like part of it is broken off. Do you mean this spade terminal? Quote Link to comment
pharouh Posted July 10, 2011 Author Report Share Posted July 10, 2011 Thanks guys! That was it! I'm stoked right now,This engine hasn't run in 10 years,and the truck hasn't moved under it's own power in 4 years. It cranks,and the lights work. Tomorrow I'm putting a little gas in it and see what happens. You guys rock! Quote Link to comment
