DISLEXICDIME Posted June 30, 2011 Report Share Posted June 30, 2011 so the hatch covers in the back of my coupe are missing most of the fasteners any one know the part number for them? are they nla? any one know where i can get some? the rattling is making me crazy! Quote Link to comment
ggzilla Posted June 30, 2011 Report Share Posted June 30, 2011 Hatch covers? 1200s don't have a hatch. The 1200 coupe has interior plastic covers inside -- lots 'o plastic. There is plastic on the bottom side of the trunk lid too. These all fastened by the typical B110 sheet screws (B210 changed to bolts/machine screws). Quote Link to comment
ggzilla Posted June 30, 2011 Report Share Posted June 30, 2011 * 08510-51612 SCREW-TAPPING M5 FIX TRIM (16 per car) 51 - Tapping screw, Pan head 05 - M5 diameter 16 - 16 mm length Type A: pan head or you could remove teh panels and drive around like this: Quote Link to comment
DISLEXICDIME Posted June 30, 2011 Author Report Share Posted June 30, 2011 Thanks. For the part number . Quote Link to comment
Morrisun Posted June 30, 2011 Report Share Posted June 30, 2011 These are what hold in the majority of the plastic panels in the back of a coupe, the back plastic that covers the tail lights, the plastic header that covers the tension rods and deck lid hinges and the panel on the underside of the deck lid. The count is about 40 of these little guys and that's the superseded part#. The bottom of the plastic in the spare tire/ fiberboard cover area are sheet metal screws with those small metal clips that slide over the holes in the sheet metal. Quote Link to comment
DISLEXICDIME Posted June 30, 2011 Author Report Share Posted June 30, 2011 These are what hold in the majority of the plastic panels in the back of a coupe, the back plastic that covers the tail lights, the plastic header that covers the tension rods and deck lid hinges and the panel on the underside of the deck lid. The count is about 40 of these little guys and that's the superseded part#. The bottom of the plastic in the spare tire/ fiberboard cover area are sheet metal screws with those small metal clips that slide over the holes in the sheet metal. That is exactly what I nead almost all of them are gone. I just looked under the car and the rear trans seal is leaking =( Quote Link to comment
Morrisun Posted June 30, 2011 Report Share Posted June 30, 2011 Sorry forgot to say but these are available at Nissan dealer and you can get rear trans seal there as well, I think I have a new trans seal if you can't get one soon. Doug Quote Link to comment
DRIVEN Posted June 30, 2011 Report Share Posted June 30, 2011 I used small pieces of foam tape along with the little guys morrisun showed. Not solid strips - just little squares every couple inches. It helped with the remaining rattles. Quote Link to comment
rusty12ver Posted June 30, 2011 Report Share Posted June 30, 2011 Funny, I just pulled all the panels off like that too. Couldn't stand the rubbing. Quote Link to comment
ggzilla Posted June 30, 2011 Report Share Posted June 30, 2011 Ah thanks for clarifying Doug. Those clips are also used on the Kick Panels for the 1200 and for the 620, and to hold down the coin trays/seat riser trim on the 1200. Quote Link to comment
