Brian D Posted June 25, 2011 Report Share Posted June 25, 2011 Can somebody tell the distance to the hood from there air cleaner with a weber carb? I am figuring out my body drop and lack a engine Quote Link to comment
flatcat19 Posted June 25, 2011 Report Share Posted June 25, 2011 Hoods are over-rated. Quote Link to comment
yello620 Posted June 25, 2011 Report Share Posted June 25, 2011 This is kinda a loaded question since it has so many variables. Which motor? L16 and L20 are not the same height.. :D And how tall of weber adapter will matter too. Along with how tall the air cleaner is. There is several heights of air cleaners for a 32/36 weber. Of course you can work with measurements that people give you if you also know what they are using. Good Luck Quote Link to comment
Brian D Posted June 25, 2011 Author Report Share Posted June 25, 2011 I am trying to get a good idea is all not perfect Quote Link to comment
albyneau Posted June 25, 2011 Report Share Posted June 25, 2011 This is kinda a loaded question since it has so many variables. Which motor? L16 and L20 are not the same height.. :D And how tall of weber adapter will matter too. Along with how tall the air cleaner is. There is several heights of air cleaners for a 32/36 weber. Of course you can work with measurements that people give you if you also know what they are using. Good Luck In broader terms from what yellow620's asking, what's more important~ channeling (or body drop~ as you puppies put it), or keeping your existing intake configuration? Or in even broader terms~ show or go? There could be a hundred peeps on here with rides similar to your goals~ but only you can decide what those goals are. Choose your path, grasshopper~ and we will be there for you... OOOSAH~:cool: Scott Now~ more nectar for the son of Zeus! :lol: Quote Link to comment
521chowda Posted June 25, 2011 Report Share Posted June 25, 2011 Hoods are over-rated. Done. Okay what's your next question Quote Link to comment
