brodster Posted June 24, 2011 Report Share Posted June 24, 2011 I have these two media-blasted timing covers. To be straight up, I am trying to sell them, but I don't know all the details. What I think is correct, is that they are from A12 engines. I was told the one with the single notch mark is from an early A12. Also, is that a speedo connection on the front of the old timing cover? Finally, which engines will this fit? Thanks for help. Quote Link to comment
metalmonkey47 Posted June 24, 2011 Report Share Posted June 24, 2011 GGzilla should be able to tell you right away what they belong to. Thats not a speedo connection though. Speedo connects at the output shaft of the transmission. Quote Link to comment
wayno Posted June 24, 2011 Report Share Posted June 24, 2011 Maybe it has something to do with a mechanical tach. Quote Link to comment
brodster Posted June 24, 2011 Author Report Share Posted June 24, 2011 I think somebody said the same thing about it being for a mechanical tach, but they weren't sure. I wonder if that was even stock. Quote Link to comment
metalmonkey47 Posted June 24, 2011 Report Share Posted June 24, 2011 I think somebody said the same thing about it being for a mechanical tach, but they weren't sure. I wonder if that was even stock. Thats possible. I've only ever seen my own A15, so I'm not sure if the A12 had a mechanical tach, but I suppose the earlier probably did. Quote Link to comment
datsunaholic Posted June 24, 2011 Report Share Posted June 24, 2011 A-series were widely used in forklifts, generators, and other non-highway use. Many of those have mechanical tachs. Quote Link to comment
ggzilla Posted June 24, 2011 Report Share Posted June 24, 2011 It might be for an aftermarket or Nismo mechanical tachometer -- it's right over the camshaft sprocket. None of the covers came that way from the factory. This single-mark cover is 1966-1970: This mutiple-mark cover is 1971-2011 (the A15 is still in production): Repair manuals say the cutover was 1973, but the parts catalog says 1971. My 1972 had the new style cover and matching crank pulley. Quote Link to comment
ggzilla Posted June 24, 2011 Report Share Posted June 24, 2011 Here's a race A-series with a tachometer drive: Quote Link to comment
brodster Posted June 24, 2011 Author Report Share Posted June 24, 2011 It might be for an aftermarket or Nismo mechanical tachometer -- it's right over the camshaft sprocket. None of the covers came that way from the factory. This single-mark cover is 1966-1970: This mutiple-mark cover is 1971-2011 (the A15 is still in production): Repair manuals say the cutover was 1973, but the parts catalog says 1971. My 1972 had the new style cover and matching crank pulley. Thank you for the info. So the timing cover will fit an A12 and A15 correct? What about the A13 and A14? I read on Wikipedia that there were some block height variations between a couple of the engines. I know on the L-20B this meant a new timing cover, but wasn't sure how this affected the A-Series. And yeah, I read the A15 was still in production too. I had to read that twice on Wikipedia. Thought I misread that the first time. Quote Link to comment
edp Posted June 25, 2011 Report Share Posted June 25, 2011 so david, can one order a new A15 long block from Nissan - got a part #? And since were on timing covers whats this one too, it confused me as well......its the bottom one w/o the water pump section thats odd - A10?? Quote Link to comment
ggzilla Posted June 25, 2011 Report Share Posted June 25, 2011 Yes, the one with multiple timing marks fits all A-series engine: A10, A12, A12A, A13, A14 and A15. The cover without the water pump bosses is a not a Datsun-Nissan A-series part. Quote Link to comment
gpimm Posted June 25, 2011 Report Share Posted June 25, 2011 I like using the timing cover with multiple marks along with the early crank pulley. Allows you to directly measure the total advance of the distributor with a simple timing light. Quote Link to comment
