makya Posted March 3, 2008 Report Share Posted March 3, 2008 ...and a few l20 heads, one u67,one a87, and one w58. Which one would you use and why? Also, who thinks LZ motors are a bad idea, I was told cracked heads are a common issue with these builds. Quote Link to comment
datsunfish Posted March 3, 2008 Report Share Posted March 3, 2008 They are all good heads but I would recommend the u67 for a LZ mod.Big valves and ports.Open chamber is good with larger displacement. I had a w58 peanut on a l20b and it liked to ping on lower octane gas.I plan to use my u67 on my LZ24 motor.Coming soon. Quote Link to comment
kiznook Posted March 3, 2008 Report Share Posted March 3, 2008 depends on how the compression numbers look. Might mock it up in the ozdat calculator and see. You're best bet will probably be the U67, like datsunfish said, bigger ports, and open chamber, helps with flow and to maintain a street-able compression ratio I don't see how head troubles could be related specifically to LZ hybrids. It's really just a L motor when all is said and done. Quote Link to comment
Z-train Posted March 3, 2008 Report Share Posted March 3, 2008 2300CC LZ stroker coming to a 620 near me soon!! Quote Link to comment
hang_510 Posted March 3, 2008 Report Share Posted March 3, 2008 i have U67's on both my LZ's for the reasons above. neither run higher than 9.5:1 Quote Link to comment
