ll77 Posted June 4, 2011 Report Share Posted June 4, 2011 hi everyone, so my hazard flashers don't work. when I turn the switch on, my turn signals don't work, when it's off they work fine, so I think the switch is okay. what should I check? think I need a replacement emergency flasher unit? Quote Link to comment
albyneau Posted June 4, 2011 Report Share Posted June 4, 2011 Your turn signal aren't supposed to work if the HazFlashers are on. After that~ we need more info. Are they coming on, but not flashing? Or..? Quote Link to comment
datzenmike Posted June 4, 2011 Report Share Posted June 4, 2011 Swap the two flasher units. If the hazards work and the turns stop working then the flasher was bad. Quote Link to comment
ll77 Posted June 4, 2011 Author Report Share Posted June 4, 2011 my hazard flashers don't work. nothing happens when I flip the switch, no flashing, no lights. but when it's in the on position, the turn signals don't work. ok, so these flashers are identical then? Thanks again, Mike, always so helpful! any other things I might check? Quote Link to comment
Javin Posted June 4, 2011 Report Share Posted June 4, 2011 are the wires plugged into your flaster unit? I know sounds dumb but sometimes we forget to check the simple things. Also, I replaced my flashers with electronic flashes... MUCH better:P Quote Link to comment
datzenmike Posted June 4, 2011 Report Share Posted June 4, 2011 my hazard flashers don't work. nothing happens when I flip the switch, no flashing, no lights. but when it's in the on position, the turn signals don't work. ok, so these flashers are identical then? Thanks again, Mike, always so helpful! any other things I might check? Close enough that you can swap them. The hazard flasher may not even be there. The switch is designed such that the turn signals are disconnected when in hazard mode. Quote Link to comment
ll77 Posted June 4, 2011 Author Report Share Posted June 4, 2011 are the wires plugged into your flaster unit? I know sounds dumb but sometimes we forget to check the simple things. Also, I replaced my flashers with electronic flashes... MUCH better:P no, I haven't taken off my dash yet, but I will as soon as it stops raining, and I will check. Close enough that you can swap them. The hazard flasher may not even be there. The switch is designed such that the turn signals are disconnected when in hazard mode. yes, that makes perfect sense. thanks everyone Quote Link to comment
Javin Posted June 4, 2011 Report Share Posted June 4, 2011 edit, never mind I am an idiot. Quote Link to comment
ll77 Posted June 5, 2011 Author Report Share Posted June 5, 2011 haha... mmm why so? Quote Link to comment
ggzilla Posted June 5, 2011 Report Share Posted June 5, 2011 My 1972 flashers work perfect. How is an electronic flasher better? Because it flashes full speed when a bulb burns out, thats no good, I want it to let me know. Did mike double-post? Quote Link to comment
