521chowda Posted June 3, 2011 Report Share Posted June 3, 2011 So im going to be lowering my 521 and i need to know if i need longer bolts for lowering the front 3"? 1 Quote Link to comment
jefe de jefes Posted June 3, 2011 Report Share Posted June 3, 2011 Longer ones not needed http://community.ratsun.net/topic/6554-reindexing-and-shocks-questions/page__p__83024__hl__reindex__fromsearch__1#entry83024 1 Quote Link to comment
izzo Posted June 3, 2011 Report Share Posted June 3, 2011 Hory shet, this has been covered a few times. a quick search would turn up some killer results. No, you dont put longer bolts in the front. you re-index the torsion bars. that means raise the truck. mark off where they rest. loosen the bolts, remove the C-clips from the torsion bars, slide them back, adjust. youll figure out how to adjust them once you are under there and are looking at it. Its best if you can index them enough, so that you can tighten the torsion bars back up snugish, and still get your drop for best ride quality. otherwise its like riding on springs. sooner or later you will want to raise your shock towers too. Make sure you get a toe alignment when your done or u will eat thru tires in 2 weeks. 1 Quote Link to comment
521chowda Posted June 3, 2011 Author Report Share Posted June 3, 2011 Oh sorry dude. ill try searching the forums next time, is it safe to use the "new" excuse? and thank you also 1 Quote Link to comment
izzo Posted June 3, 2011 Report Share Posted June 3, 2011 Oh sorry dude. ill try searching the forums next time, is it safe to use the "new" excuse? and thank you also lol. just giving you shit, search function kinda sucks. using google to search the site probably works better. 1 Quote Link to comment
68Datsun510 Posted June 3, 2011 Report Share Posted June 3, 2011 OBVIOUS N00B!!!! GET HIM!!! loljk 1 Quote Link to comment
dirtydiesel Posted June 3, 2011 Report Share Posted June 3, 2011 using google to search the site probably works better:thumbup: nice 1 Quote Link to comment
banzai510(hainz) Posted June 3, 2011 Report Share Posted June 3, 2011 no need to remove the C clips on a 521 You can do it from the front A arm. loosen the hex nut and right before its off what it with a hammer to nut ruin the threads the bar should slide out. I assume you triedd lowering the torsion bar already? and its not enough? TY this first then turn torsion bar bolt back to stock setting and reindex. then lower to your liking. might need to cut the rubber stops on the frame or remove them You might need a jack to hold drum up. 1 Quote Link to comment
Hurley Posted June 19, 2011 Report Share Posted June 19, 2011 I adusted mine 1 tooth on the spline and can get it to just about sit on the frame by adjusting the torsion bolts. 2 Quote Link to comment
521chowda Posted June 20, 2011 Author Report Share Posted June 20, 2011 I lowered it 3 inches and tool off the bump stops. Still not as low as I want it but for now it will be fine lol. Ill post pics when I get home. I guess the next step is notching it... 1 Quote Link to comment
Calbuzzard67 Posted September 29, 2015 Report Share Posted September 29, 2015 anyone have a video on raising the shock towers in the front ? 2 Quote Link to comment
