haubstr Posted May 26, 2011 Report Share Posted May 26, 2011 Did the '79-'80 280ZX come without a brake booster? Will a Master cylinder made for a brake booster work on my truck when I'm not using one? Does it matter which 280ZX Master cylinder I buy for my 521 with 4 wheel disk brakes? What is the smallest bore they made for these master cylinders? 7/8" or 15/16"? Sorry for all the questions but I only want to buy a new one once... Thanks in advance Jamie Quote Link to comment
datzenmike Posted May 26, 2011 Report Share Posted May 26, 2011 Did the '79-'80 280ZX come without a brake booster? No. Will a Master cylinder made for a brake booster work on my truck when I'm not using one? The 280zx won't fit. It way too larg a diameter and won't clear your clutch master or the steering column. A smaller booster from a 210 or a 620 should fit. Don't forget the pedistal between it and the firewall. Does it matter which 280ZX Master cylinder I buy for my 521 with 4 wheel disk brakes? '79 to '81 is best. What is the smallest bore they made for these master cylinders? 7/8" or 15/16"? 280zx masters were 15/16" Quote Link to comment
haubstr Posted May 26, 2011 Author Report Share Posted May 26, 2011 No. The 280zx won't fit. It way too larg a diameter and won't clear your clutch master or the steering column. A smaller booster from a 210 or a 620 should fit. Don't forget the pedistal between it and the firewall. '79 to '81 is best. 280zx masters were 15/16" Thank You for the response Datzenmike... Quote Link to comment
mklotz70 Posted May 27, 2011 Report Share Posted May 27, 2011 Will a Master cylinder made for a brake booster work on my truck when I'm not using one? ....hhmmm....not sure Mike read this one quite right.....or maybe I'm not....... The question as I read it, is will the m/c work without the booster.....yes, but it will take some leg to push it. My wife drives her's with a 15/16" bore m/c with no prob. But....we're both pretty short, so we get more leverage on the pedal. :) Quote Link to comment
mklotz70 Posted May 27, 2011 Report Share Posted May 27, 2011 Oh....the other thing to watch for is the tab orientation on the m/c. There were a couple of years where the tabs were up/down and had an adapter to mount to the booster......then they went to side tabs and mounted directly. Quote Link to comment
datzenmike Posted May 27, 2011 Report Share Posted May 27, 2011 Will a Master cylinder made for a brake booster work on my truck when I'm not using one? Jamie You're right Mike, he does say what you said you thought he said. Quote Link to comment
mklotz70 Posted May 27, 2011 Report Share Posted May 27, 2011 :) you get like 50 of them right to my 1 :) Quote Link to comment
haubstr Posted May 28, 2011 Author Report Share Posted May 28, 2011 :) you get like 50 of them right to my 1 :) Thanks... I'll have to watch for the tab when it comes in... I ordered the MC yesterday and going to pick it up in a few minutes... In the picture online the tabs were top and bottom... We'll see I read all the postings saying I'll need a little more leg for stopping... It's OK if my right leg is bigger than my left because of the workout driving... lol Thanks again Jamie "haubstr" Quote Link to comment
