280ZX master cylinder
haubstr
Did the '79-'80 280ZX come without a brake booster?
Will a Master cylinder made for a brake booster work on my truck when I'm not using one?
Does it matter which 280ZX Master cylinder I buy for my 521 with 4 wheel disk brakes?
What is the smallest bore they made for these master cylinders? 7/8" or 15/16"?
Sorry for all the questions but I only want to buy a new one once...
Thanks in advance
Jamie
  • Replies 7
No.
The 280zx won't fit. It way too larg a diameter and won't clear your clutch master or the steering column. A smaller booster from a 210 or a 620 should fit. Don't forget the pedistal between it and the firewall.
'79 to '81 is best.
280zx masters were 15/16"
No.
'79 to '81 is best.
Thank You for the response Datzenmike...
....hhmmm....not sure Mike read this one quite right.....or maybe I'm not....... The question as I read it, is will the m/c work without the booster.....yes, but it will take some leg to push it. My wife drives her's with a 15/16" bore m/c with no prob. But....we're both pretty short, so we get more leverage on the pedal. :)
Oh....the other thing to watch for is the tab orientation on the m/c. There were a couple of years where the tabs were up/down and had an adapter to mount to the booster......then they went to side tabs and mounted directly.
:) you get like 50 of them right to my 1 :)
Thanks... I'll have to watch for the tab when it comes in... I ordered the MC yesterday and going to pick it up in a few minutes... In the picture online the tabs were top and bottom... We'll see
I read all the postings saying I'll need a little more leg for stopping... It's OK if my right leg is bigger than my left because of the workout driving... lol
Thanks again
Jamie
"haubstr"
