70 ARC DATS Posted May 11, 2011 Report Share Posted May 11, 2011 Wat is the main difference between a l20b and a z20 and will it fit my 70 510 and dogleg with the sidedraft webbers. Quote Link to comment
datzenmike Posted May 12, 2011 Report Share Posted May 12, 2011 Wat is the main difference between a l20b and a z20 and will it fit my 70 510 and dogleg with the sidedraft webbers. The L20B and the Z20 are basically the same block and crank. The rods and pistons are different but have the same bore and stroke. Everything above the block, (head and manifolds) everything below the block, (oil pan and mounts) and everything forward of the block, (timing gear and cover) are different. You can make a Z20 into an L20B by swapping just the block. Quote Link to comment
datsunaholic Posted May 12, 2011 Report Share Posted May 12, 2011 Don't you mean "by just swapping the head"? Quote Link to comment
datzenmike Posted May 12, 2011 Report Share Posted May 12, 2011 Probably did. Put all the L20B stuff on the Z20 block. Of course it depends on the Z20 block. If with flattops the compression with an open chamber head is 9.941 Quote Link to comment
d510addict Posted May 12, 2011 Report Share Posted May 12, 2011 http://community.ratsun.net/topic/31360-lz20-write-up/ I know it's not the best writeup and I'm no genious/expert but its the info for the most part that I've found while dealing with my lz20. Quote Link to comment
