94fd3s Posted May 2, 2011 Report Share Posted May 2, 2011 Ok so I picked up another 510 this weekend. One of the previous owners decided to start shaving the corner lights, door handles, and the drip rail. They only did the driver side before they stopped. The rear corner light I can fix. I plan on getting a door and front fender because they are dented anyway. My only concern is how to go about properly fixing the drip rail. The rail was cut off from the a pillar all the way to the c pillar. Should I just purge it with argon and weld it up and shave off the one on the passenger side? Should I have someone cut one from a donor car and weld it back on? I don't think I can properly fab up a new one that will fit and allow the chrome molding to snap back on. Any advice will be appreciated. Quote Link to comment
yellowdatsun Posted May 2, 2011 Report Share Posted May 2, 2011 That's going to be entirely up to you to decide. Personally I don't like it when people shave the drip rails off. If you decide to shave the pass side too, you still have to finish fixing the drivers side. Whereas if you just fix the drivers side, you're done, and the car will look normal again. If you were to shave both sides, even after welding them up, there's going to be a LOT of hammer/filler work to make it look perfect. Then, if you come up short on the hammer work, it's going to look like a crappy botched attempt at a shaving job. Quote Link to comment
94fd3s Posted May 2, 2011 Author Report Share Posted May 2, 2011 I would like to fix it but finding a donor car in my area is not going to happen. Quote Link to comment
hobbes_the_cat Posted May 2, 2011 Report Share Posted May 2, 2011 I think the extra effort to find the donor metal would be worth it. shaved drip rails look dumb:blink: Plus if you only took a little of the roof with the drip rail when it is cut off the donor car it could probably be shipped in a tube pretty easily... lots more 510s here on the coast. Quote Link to comment
94fd3s Posted May 25, 2011 Author Report Share Posted May 25, 2011 Is the drip rail metal actually spot welded on or caulked to the roof of the car? I want to fix it but id like to know alittle bit more info about this. Quote Link to comment
datsunwizard Posted May 25, 2011 Report Share Posted May 25, 2011 Is the drip rail metal actually spot welded on or caulked to the roof of the car? I want to fix it but id like to know alittle bit more info about this. The drip rail is made of numerous layers of metal spot welded together. It is caulked to seal the roof metal to the lower pieces that form the drip rail its self. Quote Link to comment
fuzz's '71 510 Posted May 26, 2011 Report Share Posted May 26, 2011 Where in tennessee are you?? I'm down here near Huntsville, Alabama and I'm parting out a '69 4 door that you can have the rails from. Let me know and you can maybe come down and get them. Fuzz Quote Link to comment
94fd3s Posted May 26, 2011 Author Report Share Posted May 26, 2011 I'm in jackson tn. I think its about 3 hours away tops. If the rails are the same length as a 2 door and the price is right I'm interested. I just need the one from the driver side. Quote Link to comment
fuzz's '71 510 Posted May 26, 2011 Report Share Posted May 26, 2011 The car is being parted out and the price would be negotiable, the catch is I can sawzall it from post to post if that would help you. I'm kinda sure it is the same length, but don't quote me on that and if it's to long you have extra :P It will be afew weeks before the car is completely gutted and that will be when I start to chop chop. I'll save it for you if u like :huh: fuzz Quote Link to comment
inline4 Posted May 27, 2011 Report Share Posted May 27, 2011 I need the passenger rear side drip rail if you want to save it for me :) Quote Link to comment
fuzz's '71 510 Posted May 27, 2011 Report Share Posted May 27, 2011 I need the passenger rear side drip rail if you want to save it for me :) That might be do able.... :P Fuzz Quote Link to comment
yellowdatsun Posted May 27, 2011 Report Share Posted May 27, 2011 The drip rails on all 510's, except wagons, should be the same. Quote Link to comment
Super X Posted May 29, 2011 Report Share Posted May 29, 2011 There's a guy named Wayne in AU that makes them along with a few other odd peices. He ships to the US and the rates are pretty reasonable. If there is enough support he can re-make just about anything. www.automotivepanelcraft.com Quote Link to comment
