620connor Posted April 19, 2011 Report Share Posted April 19, 2011 I have a 74 620 with an L18 in it, and im getting ready to install a new timing chain kit. Do i have to drop the oil pan in order to do the job? Any info will be much appreciated. Thanks. Quote Link to comment
INDY510 Posted April 19, 2011 Report Share Posted April 19, 2011 . Use this diagram to make a timing chain holder ....... .. so you don't drop the chain into the front cover ........ ;) http://community.ratsun.net/topic/25129-quick-head-swap-write-up/ Quote Link to comment
datzenmike Posted April 19, 2011 Report Share Posted April 19, 2011 INDY I think he's changing the chain and won't need the wedge. Yes you can do this without removing the oil pan but you will have to remove the front pan bolts and a couple down each side. Maybe loosen a couple more to allow the timing chain cover to slide forward and off. You will have to remove the water pump, the distributor and the oil pump to get the timing cover off. There are also 2 small 10mm bolts on the front bottom of the head and one on each side that have to be removed and the crank pulley. Aside from that, two rad hoses, a heater hose and some fuel lines. Be sure to loosen (just loosen!) the crank pulley and the cam sprocket bolts first, then sets the motor on TDC. This will allow you to quickly time the cam when assembling. Quote Link to comment
banzai510(hainz) Posted April 20, 2011 Report Share Posted April 20, 2011 http://www.olddatsuns.com/620tech.htm http://www.youtube.com/view_play_list?p=8EF51386855F2B58 save this Quote Link to comment
620connor Posted April 21, 2011 Author Report Share Posted April 21, 2011 Thanks for the help guys. Quote Link to comment
