Charboucher Posted April 1, 2007 Report Share Posted April 1, 2007 I was wondering if anyone has set up a push button start? so that you still need the key in on position, and use the button to push start. maybe tacky for some but I kinda like them if they are done nice. I am trying to figure out witch two wires need to "touch" with button switch. anyone know? oh, my truck is a 78, but I think the last guy that had it used a 79 wiring harness. so i don't know what colors the two wiores are. Quote Link to comment
Icehouse Posted April 1, 2007 Report Share Posted April 1, 2007 This is just a guess but aren't all nissans the black with yellow stripe for the starter? I've had a few push button start rigs. Usually because the ignition is broke. Quote Link to comment
Charboucher Posted April 1, 2007 Author Report Share Posted April 1, 2007 well its not broke yet. ^_^ i;ll look into the black with yellow stripe wire . Quote Link to comment
Icehouse Posted April 1, 2007 Report Share Posted April 1, 2007 Me to, all my datto books are at my shop. Quote Link to comment
datzenmike Posted April 1, 2007 Report Share Posted April 1, 2007 Ice is right, my '78 book shows BY (black/yellow) to starter. Hook that to one side of the pushbutton and 12 volts to the other. Quote Link to comment
datsun76_620 Posted April 1, 2007 Report Share Posted April 1, 2007 I plan to use a windshield washer switch and a couple of relays... with an seperate cutout...:D ...still in planning stage... Try and hotwire that!! :cool: Quote Link to comment
datzenmike Posted April 1, 2007 Report Share Posted April 1, 2007 I plan to use a windshield washer switch and a couple of relays... with an seperate cutout...:D ...still in planning stage... Try and hotwire that!! :cool: Maybe get rid of that stoopid dash light dimmer switch and put it in there. Quote Link to comment
Bleach Posted April 1, 2007 Report Share Posted April 1, 2007 maybe don't post online how to bypass your starter kill a relay that gets its main power switched from the ignition will only allow the starter to crank after the key is in the ON position. Then just run power from that relay to the starter solinoid. Its not difficult. a hidden button is good as well. Then, take the factory starter wire that is still hooked up to the ignition switch and run that to your horns or a horn of some sort so when they do try to hotwire or use a Datsun key it will just blow the horn each time. This is of course in addition to a standard alarm but I know none of you install those. :D Quote Link to comment
Charboucher Posted April 1, 2007 Author Report Share Posted April 1, 2007 bleach thats perfect ^_^ I think I'll go with that idea! ^_^ Quote Link to comment
dat521gatherer Posted April 2, 2007 Report Share Posted April 2, 2007 my scout 2 had a push button start and i loved it. i dont know if it was factory or not. took me awhile to realize the key cylinder started it also. good luck with that. Quote Link to comment
