]2eDeYe Posted April 3, 2011 Report Share Posted April 3, 2011 The pinto shocks aren't all the shorter than the stock ones. Quote Link to comment
jesusno2 Posted April 3, 2011 Report Share Posted April 3, 2011 You"ll also notice even with a notch the top of the rearend will collide with the bed floor so unless your setup with bumpstops or cut the bed floor up it will hit Quote Link to comment
boostkiller Posted April 4, 2011 Author Report Share Posted April 4, 2011 i took off all the bump stops but was gunna cut the rear in half so that wouldent happen Quote Link to comment
]2eDeYe Posted April 4, 2011 Report Share Posted April 4, 2011 Cut the rear in half? The pumpkin will still hit the bed floor is what Jesus Knows.... Quote Link to comment
yello620 Posted April 5, 2011 Report Share Posted April 5, 2011 i took off all the bump stops but was gunna cut the rear in half so that wouldent happen Do you have the 521 rear bump stops that are like seven inches tall and look like an "8"? Cutting those in half should help you a lot, and i bet that the differential still doesnt hit the bed floor. Quote Link to comment
boostkiller Posted April 5, 2011 Author Report Share Posted April 5, 2011 ya the bump stops i have are huuuuuuuge. and i have a good foot maybe more before the bed hits the diff Quote Link to comment
daniresch Posted May 18, 2011 Report Share Posted May 18, 2011 wheels are only temporary. when work picks up ill be throwing some bbs rs's 17x? with a super low offset. i'd def like to see pictures of this, but 6 lug :mellow: Quote Link to comment
