Rastamaoli Posted February 23, 2011 Report Share Posted February 23, 2011 Ok I am considering doing a engine swap if it is able to modify which is highly unlikely. Could anyone elaborate on what I would need to begin the project? Thanks Quote Link to comment
sick620 Posted February 23, 2011 Report Share Posted February 23, 2011 same as any swap.... motor mounts, tranny mounts, driveline, wiring it up and putting it all together.. Quote Link to comment
ezcruiser Posted February 23, 2011 Report Share Posted February 23, 2011 Not bashing but I would have searched for "sr20 620", "sr20 swap", "620 swap" or something comparable to what you are after. I just thought of vegas_datsun's swap immediately after seeing your post. Here's the link: sr20det 77' 620 He says that it uses the stock engine mount locations in the 620 without modification to the crossmember, but it looks like the cross bar has to be switched to the bottom side of the idler arm and steering gear arm. If you don't believe me check out the mount in this picture: Quote Link to comment
datzenmike Posted February 23, 2011 Report Share Posted February 23, 2011 The SR won't mount to the 620 tranny so you will need that too. Quote Link to comment
