doughboi916 Posted January 11, 2011 Report Share Posted January 11, 2011 has anyone used these ebay coilovers on the 510/280 swap?? im now looking into front suspension.. i got the 280 strut perches off. just ordered the tokicos.. http://cgi.ebay.com/ebaymotors/Datsun-Z-240Z-510-280Z-Coil-Overs-Coilovers-Springs-_W0QQcmdZViewItemQQhashZitem5d2ce50a4dQQitemZ400185166413QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Ive looked at all the kits they have like t3 and all the rest but there all around 200 bucks.. is there a cheaper solution? also about were on the strut is the stopper welded on? Quote Link to comment
jefe de jefes Posted January 11, 2011 Report Share Posted January 11, 2011 The top hats look like rubber? Quote Link to comment
hobbes_the_cat Posted January 11, 2011 Report Share Posted January 11, 2011 I asked this question a while back and got a mixed response. Most who didn't like this particular set said it was cause of the cheap lookin top hats. the $199 sets have steel or aluminum hats. the other problem is no choice of spring rate with the ebay ones. other brands like t3 or ground control let you pick spring rates. Quote Link to comment
doughboi916 Posted January 12, 2011 Author Report Share Posted January 12, 2011 i just emailed him too see what the top hats were made of just to make sure.. it says there 200lb spring rate.. i think ill give them a try depending what the top hats are made of... if anything i can always change out the springs..Rite?? Quote Link to comment
hobbes_the_cat Posted January 13, 2011 Report Share Posted January 13, 2011 yeah you can change the springs later, but you might have to spend another $75. If you do get them let us know how they work out, I'm curious. Quote Link to comment
datzenmike Posted January 13, 2011 Report Share Posted January 13, 2011 There is still a limit to how far you can lower the front without bottoming out the strut. Usually a shorter strut is used and the strut tube shortened to match and welded up again. 280zx and 300zx are shorter than the stock 510 to begin with but can be shortened even more with the right insert. Generally front springs are between 200 to 300 pounds. Rears are 600-700 and up to 1000. also about were on the strut is the stopper welded on? I wouldn't weld because that's too permanent. What you need is an adjustable pipe clamp that can be moved up and down the strut tube. Quote Link to comment
doughboi916 Posted January 13, 2011 Author Report Share Posted January 13, 2011 i think ill skip out on em.. the top hats are plastic.. he said him self that they were in his personal 510 and it was a bit bumpy.... I guess im ordering from T3? unless some one has a used set there trying to sell????? Quote Link to comment
