jesusno2 Posted January 27, 2008 Report Share Posted January 27, 2008 WOW! thats all i got to say that thing packs a punch my old 720 has never ran so good that was money well spent! now if i only had another to put on the exhaust side! just in case any of ya wanna get one and put it on a napz engine heres how ya hook it up. Coil A (intake coil) has a WHT/YEL on the Coil+ terminal, and RED on Coil- - Remove the Red wire from the coil and attach it to the WHITE wire of the MSD box. - The Small BLACK wire of the MSD box will now connect to that coil- terminal. - The WHT/YEL wire will be removed from the coil and attached to the Small RED wire of the MSD box. - The ORANGE wire from the box will connect to the Coil+ terminal. I suggest to verify that the WHT/YEL wire is the 12V supply before performing this installation. downfall to the msd box is that the factory tach no worky no more. I belive their is a way to hook it back up but i'm unsure of how to do this right now. Quote Link to comment
hang_510 Posted January 28, 2008 Report Share Posted January 28, 2008 tach adapter for the factory tach...maybe #8920 Quote Link to comment
datrod Posted January 28, 2008 Report Share Posted January 28, 2008 tach adapter for the factory tach...maybe #8920 that will make it workey. had to put one on my 240. Quote Link to comment
allen dodson Posted January 31, 2008 Report Share Posted January 31, 2008 I saw a 521 on t.v. that had custom cut bre fender door angle decals. SWEET. Any one know were to order the bre decals? Quote Link to comment
sjeff64 Posted February 1, 2008 Report Share Posted February 1, 2008 don't need one for the exhaust side. those plugs dont fire when it warmed up,or at least it does nothing for performance.(but I am pretty sure about the warm up thing) Quote Link to comment
datzenmike Posted February 1, 2008 Report Share Posted February 1, 2008 The Z24 series motors ran with both set of plugs firing. The Canadian Z24 and later Z24i motors had a vacuum switch to turn one set off under heavy load conditions to reduce engine noise, but fire both at all other times. The motor is designed to run this way and runs poorly only on one set. jesusno2 The tach is run off the intake set of plugs, I believe. If you switch the MSD to the other coil and set of plugs (exhaust) you would have your tach back. Quote Link to comment
