imtb Posted December 29, 2010 Report Share Posted December 29, 2010 Can anyone let me know which is the hot and ground on the External 280zx electric fuel pump. I am installing one but not sure what is hot or ground. It has one black and on color wire with a stripe. The pump also has two differnt size post for the wire to attach. I am updating my fuel tank, new fuel feed and return lines. Thanks mike Quote Link to comment
datsunaholic Posted December 29, 2010 Report Share Posted December 29, 2010 I THINK the larger terminal is the positive. The all-black wire is negative. All the 280Z/ZX pumps I've seen had +/- marked near the terminals in the plastic end. Quote Link to comment
datzenmike Posted December 29, 2010 Report Share Posted December 29, 2010 Black will be ground. Green is the power wire I believe. Quote Link to comment
imtb Posted January 13, 2011 Author Report Share Posted January 13, 2011 Ok I got the fuel pump mounted and wired up it working good once I got all the leaks fixed. I pull the tank and had a new pickup install and AN6 fitting for the return and I ran new 3/8 supply and return lines, for whenever I run FI or Boost. I have the fuel pump wired up through Holley Oil pressure switch, so it turns off if no oil pressure. Here is a couple of pics. Quote Link to comment
banzai510(hainz) Posted January 13, 2011 Report Share Posted January 13, 2011 YOu still running those Mikuni motorcycle carbs? Quote Link to comment
dryheat Posted January 14, 2011 Report Share Posted January 14, 2011 Really nice work Mike. I always thought that the void behind the fuel tank support bracket was a great spot to put an external pump. Where did you hide your fuel filter at? Quote Link to comment
