Cg240sx Posted January 20, 2011 Report Share Posted January 20, 2011 did you have to swap out your oil pan? im doing the same swap but its going in a 521 i tried putting it in but it seems like it wont clear with the stock oil pan :/ Quote Link to comment
Wide14u Posted January 23, 2011 Report Share Posted January 23, 2011 No change. Just wondering, I wasnt sure why others were doing it, and if it was a better idea or not.:D i went with the 720 trany because i did want to get the drive shaft done in case it broke i wanted to go to wrecking yard and find parts Quote Link to comment
sanitys Posted January 23, 2011 Report Share Posted January 23, 2011 the wiring really isnt hard...its about 8 wires and then just cleaning up the wiring...all you need is a fuse box, some relays, a solder gun/solder and some heat shrink. i re-read and you said jason is making your harness, he does good work. I re-made mine when i switched over to the aem computer. Quote Link to comment
]2eDeYe Posted January 23, 2011 Report Share Posted January 23, 2011 did you have to swap out your oil pan? im doing the same swap but its going in a 521 i tried putting it in but it seems like it wont clear with the stock oil pan :/ You have to flip the center link and clearance the pan a bit. Quote Link to comment
slinginabullet Posted January 23, 2011 Report Share Posted January 23, 2011 you can't flip the center link unless you do major work they are tapered well I guess it could but might not be safe. Just take a body dolly and place it on the back side of the pan were the center link would hit and pound it in do a couple test fits until right. But that is just my 2 cents Oops sorry didn't see it was going in 521 so then I don't know but that is how I did it for my 620 Quote Link to comment
]2eDeYe Posted January 23, 2011 Report Share Posted January 23, 2011 you can't flip the center link unless you do major work they are tapered well I guess it could but might not be safe. It is a bit of work to do correctly, but it is no less safe than the stock taper. That is done by welding up the existing holes and re-tapering the arms from the other side. Quote Link to comment
slinginabullet Posted January 23, 2011 Report Share Posted January 23, 2011 ya I just read your thread nice build but just a little more costly if your on a budget Quote Link to comment
]2eDeYe Posted January 24, 2011 Report Share Posted January 24, 2011 For sure. Next time I'm buying the ream and doing it myself. Quote Link to comment
620Reaper Posted January 27, 2011 Author Report Share Posted January 27, 2011 I bought a new grill the other day for my baby.:D Quote Link to comment
620Reaper Posted January 27, 2011 Author Report Share Posted January 27, 2011 I was so excited today at work. My wiring harness came in today! Thanks a lot to Beebani, havent installed the harness yet but I hope in doing everything soon.:cool: More pics for you guys! Quote Link to comment
]2eDeYe Posted January 28, 2011 Report Share Posted January 28, 2011 I bought a new grill the other day for my baby.:D New???? Quote Link to comment
620Reaper Posted January 28, 2011 Author Report Share Posted January 28, 2011 2eDeYe' date='27 January 2011 - 10:15 PM' timestamp='1296191727' post='418469']New???? I actually got lucky and found it at the junk yard.:D but its new to me.;) Quote Link to comment
]2eDeYe Posted January 28, 2011 Report Share Posted January 28, 2011 Nice score, it looks new :D Quote Link to comment
KA620KC Posted January 30, 2011 Report Share Posted January 30, 2011 Awesome job. I'm amost done with my KA swap. I used the KA tranny and all I had to do was slot the crossmember about an extra 1/2" and beat the tranny tunnel a bit to clear the "spine" on the trans. As for the driveshaft I am reusing the stock KC driveshaft but getting it shortened roughly 3". I won't be doin that myself though. I can weld but I don't trust welding something that important. I like the info about the automatic computer though!! I'm probably the most impatient person I know and I m itching to finish it!!! Quote Link to comment
620Reaper Posted January 30, 2011 Author Report Share Posted January 30, 2011 Awesome job. I'm amost done with my KA swap. I used the KA tranny and all I had to do was slot the crossmember about an extra 1/2" and beat the tranny tunnel a bit to clear the "spine" on the trans. As for the driveshaft I am reusing the stock KC driveshaft but getting it shortened roughly 3". I won't be doin that myself though. I can weld but I don't trust welding something that important. I like the info about the automatic computer though!! I'm probably the most impatient person I know and I m itching to finish it!!! Thanks for the info man, I can use all the help I can get.:D Im getting really impatient too with my build. lol Quote Link to comment
620Reaper Posted April 9, 2011 Author Report Share Posted April 9, 2011 So i ran into a problem today. Im guessing everyone has gone threw this already. My tie rod end hits the oil pan. Do i use a different oil pan or do i mod this one... pics will help me out a lot if ya'll have any.:huh: Quote Link to comment
]2eDeYe Posted April 9, 2011 Report Share Posted April 9, 2011 You will have to clearance the pan. I flipped my tie rod to gain even more room. http://www.jeepfan.com/reviews/review_retieflip.htm If you flip the center link, make sure the taper is correct for the tie-rod ends. Quote Link to comment
KA620KC Posted August 21, 2011 Report Share Posted August 21, 2011 So whats the update on the build? Quote Link to comment
Newto620 Posted August 21, 2011 Report Share Posted August 21, 2011 im new to tha 620 i have a couple of 240 that i love so i want to do a 620 since i saw one being done in progect car mag with the sr swap so im reaching out to anyone that can help and give me some good tips on how i need to go about it. im going for the drift 620 truck for mine. I want it to look like a import tuner. thank for any tips Quote Link to comment
