bredatto510 Posted December 27, 2010 Author Report Share Posted December 27, 2010 no i did i had it at 12 but someone told me to go to 15 to retard it yea stupid i know so i put it at 15 and now right now i dont have a light on me so i just retarted it a bit and it seems to help Quote Link to comment
nismo dr Posted December 27, 2010 Report Share Posted December 27, 2010 ah, that makes me feel better, seemed like alot of work to throw at it when a $20 tim light might fix it. carry on Quote Link to comment
bredatto510 Posted December 27, 2010 Author Report Share Posted December 27, 2010 no yea i know... im thinking water injection now so i know set it back to 12 btdc and have power but for as much money as im gonna spend it might just be better to put some l18 pistons.. only thing is this is my daily and i wouldnt want to have it down to pull out the pistons and everything Quote Link to comment
banzai510(hainz) Posted December 27, 2010 Report Share Posted December 27, 2010 bredatto Ever datsun guy should have a timming light! However you really dont need one unless soemthing is terribly off. I would retard it to get rid of the ping or dont drive it as hard. Most engines want most amount of adv before it pings. try running it w/o the vacuum adv(not all sidedraft have a vac adv port on the carb). YOU MAKE SURE YOUR NOT RUNNING IT OFF THE MANIFOLD!!!!!!that is a big NO NO. Be honest your in a catch 22 situation. Dave on here ,Icehouse friend he had the same proplem with a LZ motor with flattops. It ran good with race gas but he was going broke doing it. He also did the 50/50 mix as you did. However for a daily driver weekend car its just not as fun lookn for this exp$$$ gas. Quote Link to comment
bredatto510 Posted December 27, 2010 Author Report Share Posted December 27, 2010 oh damn i am running the vacuum advance off the manifold... i dont drive it hard and i dont mind that i enjoy cruising it... so just disconnect the vacuum advance... should i plug it? and plug the manifold too?... also there is one vacuum under each carb should those be plugged off as well? Quote Link to comment
datzenmike Posted December 28, 2010 Report Share Posted December 28, 2010 ok so i loosened the dizzy and move it clockwise quite a bit all the way i believe while it was running of course at running temp and with the vacuum advance taken off... then i adjusted the carbs idle screws to keep it running... im gonna take it for a test drive to see how it is Clockwise on the dizzy will advance the timing! Retard it. Since there is no exact number, just turn the dizzy counter clockwise to retard (lower) the advance. Trial and error. Loosen the dizzy bolt just enough so you can turn by hand. Take for a drive and see how your adjustment is working. Stop and turn by hand and try again. Keep retarding it until it goes away or is just barely noticeable under load. . Quote Link to comment
datzenmike Posted December 28, 2010 Report Share Posted December 28, 2010 oh damn i am running the vacuum advance off the manifold... i dont drive it hard and i dont mind that i enjoy cruising it... so just disconnect the vacuum advance... should i plug it? and plug the manifold too?... also there is one vacuum under each carb should those be plugged off as well? Crap you don't have a stock carb!!!! This would have been good to know. Quote Link to comment
bredatto510 Posted December 28, 2010 Author Report Share Posted December 28, 2010 yea thats what i mean my bad... i went counter clock wise.... yea and im guessing i have vacuum leaks.. they are s5 mikuni 44's Quote Link to comment
bredatto510 Posted December 28, 2010 Author Report Share Posted December 28, 2010 ok i retarded it all the way till it wouldnt turn on... then i slowly advanced it until i got it to turn on then a little more till there was no rough acceleration and turns off fine... tomorrow i will go to my local auto parts and pick up some vacuum caps for the vacuum advance on the dizzy as well as the intake manifold and the two beneath the carbs... thanks for the help ill keep u guys updated Quote Link to comment
banzai510(hainz) Posted December 28, 2010 Report Share Posted December 28, 2010 plug the manifold hole.That is important the distributor adv canister hole I just leave alone. dont need to be pluged. Now under the carbs far as I know those are overflow tubes or soemthing. I dont think they are vacuum adv tubes. You better be sure as I have 44mm and they dont have a vac adv port and underneath there is nothing. I have seen some Mikunis with overflow tubes.So I think you would leave these open!!!!!!!!! now with the manifold plugged time the motor to between 12-15 degs. then run it hard when warmed up. If pinps then then reatrd the dizzy a little. till it stops pingn or dont drive it has hard. this will be the simplest and cheapest method to keep this motor going w/o taking the head off. By 91 or better octane. Quote Link to comment
bredatto510 Posted December 28, 2010 Author Report Share Posted December 28, 2010 ok thanks hainz yea thats wat im gonna do Quote Link to comment
