NW510Drifter Posted December 19, 2010 Report Share Posted December 19, 2010 So I got a 72 510 with l20b, battery wasn't charging allthough the alternaters good. Had a mechanic friend help me out, connected white with red stripe wire coming from regulater to white and red wire from the ignition. Now my cars running at 13 amps but the charge light is always dimly on...even with key out, can annyone help me Quote Link to comment
datzenmike Posted December 19, 2010 Report Share Posted December 19, 2010 So I got a 72 510 with l20b, battery wasn't charging allthough the alternaters good. Had a mechanic friend help me out, connected white with red stripe wire coming from regulater to white and red wire from the ignition. Now my cars running at 13 amps but the charge light is always dimly on...even with key out, can annyone help me The White/Red wire from the regulator doesn't go to the ignition. It goes to one side of the Red charge light. The White/Blue goes to the ignition switched side of the fuse box. If that helps. Quote Link to comment
bonvo Posted December 19, 2010 Report Share Posted December 19, 2010 13 amps? you mean volts? if theats the case thats not enough to keep the battery charged and this is the wrong section for this post Quote Link to comment
datzenmike Posted December 19, 2010 Report Share Posted December 19, 2010 Good eye. I've moved to Electric. Quote Link to comment
NW510Drifter Posted December 26, 2010 Author Report Share Posted December 26, 2010 yeah volts.. little typo I'm gonna go try switching some wires thanks datzen mike Quote Link to comment
DISLEXICDIME Posted December 26, 2010 Report Share Posted December 26, 2010 internal or externally regulated Quote Link to comment
NW510Drifter Posted December 26, 2010 Author Report Share Posted December 26, 2010 external Quote Link to comment
