Icehouse Posted December 6, 2010 Report Share Posted December 6, 2010 Has anyone had that problem? HAHA Mine does for some reason. I didn't realize why until I had some duct tape I used to hold the door in defrost mode, I had the door down because my window was clear. When I turned the heater on it sucked the tape that was hanging down into the heater...WTF! It's a Bluebird heater box which looks the same as a 68 and since mine was messed up I just swapped an NOS core I had in and hooked up the wires. The plug fit and all seemed fine until I turned it on in the car and noticed it's sucking air instead of blowing it..... Which wouldn't be such a big deal if it wasn't freezing cold out! How am I supposed to daily drive the gobstopper car if I have to be moving to defrost my window. It's almost as bad as a VW bug! Quote Link to comment
INDY510 Posted December 6, 2010 Report Share Posted December 6, 2010 . My electric fans on the radiator will spin backwards if the wires are backwards..... . . but that might hurt your NOS fan Quote Link to comment
datzenmike Posted December 6, 2010 Report Share Posted December 6, 2010 JDM are positive ground.???Swap the wires, it's a DC motor and will run the other way if you reverse polarity. Quote Link to comment
datsun65 Posted December 6, 2010 Report Share Posted December 6, 2010 I used to own a 64 Datsun that originally was positive ground, but I switched the car over to negative ground. Same thing happened, the fan ran in reverse. Try swapping the wires? Quote Link to comment
Icehouse Posted December 6, 2010 Author Report Share Posted December 6, 2010 Yeah I know I can reverse the wires just thought it was kinda odd that using all factory crap and it's doing that... Weird... Quote Link to comment
