boxboy Posted October 31, 2010 Report Share Posted October 31, 2010 So I was trying to press in my new kingpin bushings this afternoon and ran into a major issue. As I pressed them I noticed there was metal shavings curling up around the hole as it went in. I double checked and everything looked lined up well, so I tried to go a little further. OOOPSS!! The bushings have a seam in them and one side of the seam started to lean in or out or something and the bushing buckled. Now what? I am looking for somewhere to buy bushings now without buying a whole kit again. Anyone know where to get these? I have contacted Nissanpartscc, but as it is the weekend I will have to wait. Anybody have the secret to pressing in the bushings without this happening? I was using a flat washer to provide even pressure and a bolt to keep it aligned. Should the bushing peal like that as I press it in? Quote Link to comment
yello620 Posted October 31, 2010 Report Share Posted October 31, 2010 The bushing will often peel a little when pressing them in, reasonably normal. If you do not have the right press tools, the bushing will buckle every time. Do you have the proper size bushing ream to use after you get the bushings pressed in?? Dont waste you time looking for individual bushings, I have been doing front end work for twenty years and have never seen the bushings available separately, doesnt mean it cant happen though--good luck. Quote Link to comment
datzenmike Posted October 31, 2010 Report Share Posted October 31, 2010 Bushing king pin J13 motor 520........ Nissan part # 40016 26762 qty. 4 about $3 (each maybe, not sure) L16 motor is different number. Quote Link to comment
boxboy Posted October 31, 2010 Author Report Share Posted October 31, 2010 Where do these come from Mike? I have that number, and Nissanpartscc had them for $2.43, but they are yellow dot. I really hope I don;t have to pay $70 for a new entire kit!:( Quote Link to comment
datzenmike Posted October 31, 2010 Report Share Posted October 31, 2010 Nissan part # 40016 26762 Nissan but they may be unavailable. Talk to you local dealer. See if he can ask other dealers to look in their in house inventory. Someone may have ordered them and not picked them up and are sitting on a shelf. They'd probably love to get rid of them. Failing that you may be able to take a good one to a machinist and have him make one from a brass pipe fitting??? They have to be reamed to size anyway. Quote Link to comment
banzai510(hainz) Posted October 31, 2010 Report Share Posted October 31, 2010 if in dought take it to a machine shop that has replaced these bushings before. You need a oversize reamer of some sort. and these are not cheap as its a certain size.MOST people dont buy these. you read the write up on Olddatsuns.com by Mike Klotz just have him do it Quote Link to comment
boxboy Posted November 1, 2010 Author Report Share Posted November 1, 2010 Yeah, after this experience I will be taking it somewhere. I just hope I can find some bushings. I suppose if the bushing has been pushed out of round at all it is unsalvageable. It isn't real bad and it is only pushed in about 3/16 inch. Mklotz was kicking around the idea of doing it for me. I guess I should have just waited and had him do it in the first place. Lesson learned. Quote Link to comment
boxboy Posted November 10, 2010 Author Report Share Posted November 10, 2010 Finally took some pics. Hope you can see what happened. I have some leads on new bushings, just the waiting game for now. Quote Link to comment
